Rear stabilizer bar part numbers?
Discussion in '2.5 Gen Tundras (2014-2021)' started by flloyd, Aug 26, 2021.
  1. Aug 26, 2021 at 6:28 PM
    flloyd
    flloyd [OP] New Member
    flloyd
    Hey anybody, does anybody have any access to rear sway bar hardware part numbers? I have been looking for hrs. I am looking for the "Upper end link bolts (2) and spacers (2) to attach my sway bar to the frame. that is all i need. I really don't want to buy a kit for just those. thanks for any info. I will buy those from anybody that might have them.
  2. Aug 26, 2021 at 6:38 PM
    I'm not sure that you can get those individually. I think someone needed the same thing a while back.
    https://toyotaparts.bochtoyotasouth...MIx6OZgIjQ8gIVF4eGCh0vmAzrEAQYBSABEgJ1R_D_BwE
  3. Aug 26, 2021 at 6:42 PM
    The sizes are listed in the instructions if that helps any.
    crewmaxlmt likes this.
  4. Aug 26, 2021 at 6:44 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    They are just bolts,washers,and spacers. You should be able to source them all from McMaster carr. The bolts are the same as hitch bolts with the added length of the upper end thickness. Make sure that you get 12.9 grade bolts. For the spacers, select some bronze ones. There should be plenty to choose from.
    Tundra234 likes this.
