Rear shocks
Discussion in 'Suspension' started by Stulloh, Jan 30, 2018.
  1. Jan 30, 2018 at 4:12 AM
    Stulloh
    Stulloh [OP] New Member
    Dallas
    18 Tundra TSS
    ok so I installed 6112s bilsteins on the front, ride is much improved but am now ready to deal with the rear as I get a tad bed bounce....should I stay with bilstein and do the 5100 series or ?
  2. Jan 30, 2018 at 4:56 AM
    Check out the Bilsteins 5160 series shocks. These are the ones that were recommended to me when I upgraded to 6112s on my Tundra.
    No regrets on that purchase.
  3. Jan 30, 2018 at 5:01 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Ditto
  4. Jan 30, 2018 at 5:53 AM
    kurtwp
    kurtwp What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    If you are on the road more then off I would save some money and get the 5100s
    Kurt
  5. Jan 30, 2018 at 5:58 AM
    Dejohnson8034
    Dejohnson8034 New Member
    Prosper, Texas
    2017 Tundra Limited
    I installed the 6112's on the front and the 5160's on the rear of my 2017 Limited this last weekend; the ride quality increased substantially. I was going to put the 5100's on the rear but changed my mind; they are sitting in the box in my garage.
  6. Jan 30, 2018 at 8:48 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Steve, as Kurt mentioned above, unless you off-road as much as on the street, save ur money. I have 6112's with 5100's in rear and the ride is a big improvement over my old trd shocks. Just my .02
  7. Jan 30, 2018 at 9:44 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    if you're going to do it, i'd spend the extra $100 or so dollars and get the 5160's. They won't cure your bed bounce, but they helped out significantly.
    ColoradoTJ and TheBeast like this.
  8. Jan 30, 2018 at 10:04 AM
    TheBeast The Beach
    +1 on the 5160
    Stuffs and Larmand like this.
  9. Jan 30, 2018 at 10:49 AM
    Rotty23
    Rotty23 New Member
    Phil
    Upstate SC
    2014 1794 CM 4x4 Blue Ribbon Blue Metallic
    TRD Pro grill, TRD rear sway bar, Bilstien 6112 up front set at middle setting, Bilstien 5160s on rear, BFG KO2s on Method 20x9 wheels, drilled and slotted rotors, color matched front bumper caps, mirror caps and door handles, BA 8" stainless exhaust, TRD Pro skid plate, drivers side grab handle
    I would use the 5160s...I have them and they ride great
