Rear Shock Suggestions
Discussion in 'Suspension' started by patterson.walter, Aug 30, 2021.
  1. Aug 30, 2021 at 8:25 AM
    patterson.walter
    patterson.walter [OP] New Member
    Walter
    2007 white SR5 5.7 db cab
    2007 SR5 5.7l DBL Cab
    I am looking for rear shock suggestions for my Tundra. 1 shock is leaking and the other is a cheap replacement that is a sad excuse for a shock. I plan on towing 5000 lbs travel trailer next month and will be ordering a set of timbren's this week to install.
    I really want the truck to have a "nice" ride close to the OEM and am looking for around $50 a shock if possible, but any suggestions would be nice. I am also putting Sulastic shackles on in December as a Christmas present to myself.
    Thank y'all in advance.
  2. Aug 30, 2021 at 8:39 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I am unaware of any quality shock under 50.
    patterson.walter[OP] likes this.
  3. Aug 30, 2021 at 8:45 AM
    2mchfun
    Hit salvage yards
  4. Aug 30, 2021 at 8:54 AM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
  5. Aug 30, 2021 at 8:56 AM
    Elduder
    Elduder New Member
  6. Aug 30, 2021 at 9:05 AM
  7. Aug 30, 2021 at 9:15 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
  8. Aug 30, 2021 at 9:32 AM
    Elduder
    Elduder New Member
    They were better than the stock ORs I took off…
  9. Aug 30, 2021 at 9:36 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    I was referencing that the aftermarket Bilsteins have a much stiffer ride. I should have clarified. The Eibachs were hands down better than stock on my 4Runner and the Bilstein 5100 equipped 4Runner I was in.
  10. Aug 30, 2021 at 9:44 AM
    Elduder
    Elduder New Member
    Agreed, the aftermarket Billys were a bit stiff when I had them, but that was on a Tacoma and a 4Runner. Ill eventually put the Eibach on our 4Runner, I was a fan of them when I had them on the Tundra.
  11. Aug 30, 2021 at 12:54 PM
    patterson.walter
    Walter
    LOL thank y'all for the suggestions I am going to buy a pair of the Eibachs shocks. Its only an extra $100 and will keep me from the dreaded rock auto shocks I was looking at. Up until now I have really only driven VW's. I know were and what parts to get because they are always needing some kind of maintenance part. Toyota not so much.
    Once again thank you
  12. Aug 30, 2021 at 1:15 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    Well worth it…good luck and enjoy!
  13. Oct 2, 2021 at 7:25 AM
    patterson.walter
    Walter
    I have already put 3k on the eibach’s and they are really an excellent put together product and have a good solid feel and improved ride quality. I like that they are USA made.
    Thank you for the suggestion
