rear shock replacement video ?
Discussion in 'Suspension' started by wigburner, Jun 18, 2019.
  1. Jun 18, 2019 at 4:24 PM
    wigburner
    wigburner [OP] New Member
    09 double cab 5.7
    why is it so hard to find one?
    it seems simple enough but i'm good missing shit and making it harder than it should be
  2. Jun 18, 2019 at 5:19 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is there a particular thing youre stuck on? Its pretty simple. I jacked it up, dropped the axles most of the way to full droop. Pulled off the top nut. Pulled bottom nut, smacked the bolt out with a hammer then removed the shock down and away
  3. Jun 18, 2019 at 6:26 PM
    wigburner
    09 double cab 5.7
    i couldn't figure out how to delete the post.
    yet i figured how to put the shocks in.
    thanks
    Black Wolf and justfortun like this.
  4. Jun 18, 2019 at 6:57 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Good job! You saved yourself a 100 bucks in labor.
    Hbjeff likes this.
  5. Jun 18, 2019 at 7:15 PM
    AZTundra
    Paul
    Phoenix, AZ
    Let's see some pictures! Glad you were able to get it squared away.
  6. Jun 19, 2019 at 12:36 PM
    wigburner
    09 double cab 5.7
    my truck ain't pretty it just works
    Black Wolf likes this.
  7. Jun 19, 2019 at 2:10 PM
    cpc0812
    cpc0812 New Member
    Cory
    2018 Cement 4 X 4 CM
    I didn’t even jack it up. I can’t remember which end I bolted up first(top or bottom). Then I compressed by hand and bolted up the other end. It wasn’t easy but I did it.
    15whtrd and wigburner[OP] like this.
  8. Jun 19, 2019 at 4:04 PM
    wigburner
    09 double cab 5.7
    wheels and all huh?
    badass
  9. Jun 19, 2019 at 4:12 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Don’t even need to Jack the truck up. Loosen top nut. Loosen bottom bolt and remove. Remove top nut. Remove shock. Insert new shock in top mount. Loosely install nut to hold in place and push the shock up by hand till you line up the holes and slip the bolt in. Torque to spec and yours good to go.
    Toyoda Tundra likes this.
  10. Jun 19, 2019 at 4:59 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Depends on what kind of shock you’re putting in. Oe shock can be collapsed by my daughter.
  11. Jun 20, 2019 at 1:52 PM
    cpc0812
    cpc0812 New Member
    Cory
    This is what I did.
    Yes it does. My fox 2.0s on my last Tundra were easier than my Bilstein 5100s on my current truck.
  12. Jun 20, 2019 at 1:58 PM
    wigburner
    09 double cab 5.7
    4F24A152-A7EF-47BA-80D1-AF87C863858E.jpg EA3F6820-20CE-44A3-BF27-D2593D832D35.jpg
    AZTundra[QUOTED] and Jrharvey02 like this.
  13. Jun 20, 2019 at 2:13 PM
    15whtrd
    15whtrd Mr. Blonde
    I’ve done it the same way on my last truck. This time I had my truck jacked up but didn’t remove the wheels nor did I have it completely off the ground.
    AZTundra likes this.
  14. Jun 21, 2019 at 4:16 AM
    kleiker0303
    kleiker0303 New Member
    Kyler
    Kansas City
    ‘16 Platinum
    Bilstein 6112 @ 1.9" Bilstein 5100's in rear Afe drop in filter Afe intake tube Afe throttle body spacer Afe catback with vibrant resonator added Stubby antenna TRD front grill Paint matched door handles Paint match mirror caps RCI skid plate All LED bulbs Undercover flex cover 20% tint all around Husky floor liners ESP under seat storage 2018 headlight mod Baja designs fog light kit 275/60/r20 falken wildpeak at3w 20x9 fuel ripper
    Got around to replacing the rear shocks with 5100's. First time doing a shock replacement so I felt more comfortable jacking the truck up and removing the wheel. In hindsight none of that is necessary. With jacking up and tire removal total install time for Both sides was about 30-45 mins. Super easy to do and made a nice improvement over the stock rear shocks.
    15whtrd likes this.
  15. Nov 17, 2020 at 8:52 AM
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Just wanted to share some insight because that top nut just whipped my ass for close to 2 hours. I couldn’t get a crescent wrench or any variety of wrenches to bite on the bolt itself (it seemed a little rounded from the wrench slipping off). I wound up cutting the boot and holding the piston rod right below the rubber bushing. This was much easier then holding it above the nut where there is no space.
    TundraCM12 and trucknut like this.
  16. Jan 9, 2021 at 12:07 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Thanks for the insight. I was in the same boat but this did the trick
    dpast88[QUOTED] likes this.
  17. Jan 11, 2021 at 5:44 AM
    TXTundraFan
    TXTundraFan New Member
    4x4 gypsy likes this.
  18. Oct 12, 2022 at 1:16 PM
    biggsy
    biggsy New Member
    Warren
    2010 Tundra DC Rock Warrior
    Hello!
    I've replaced rear shocks on my previous vehicle (2002 4runner) but just to make sure I do things correct, should I torque with suspension loaded or while its in the air on jack stands is fine? I know the leaf springs and u bolts are done with suspension loaded on the ground. Thanks
