Rear Shock length on only a Shackle?
Discussion in 'Suspension' started by ctdomain, Oct 24, 2019.
  1. Oct 24, 2019 at 6:49 AM
    ctdomain
    ctdomain [OP] Expeditioner
    Clint
    2019 Limited Quicksand Tundra
    Suspension: ADS Front C/O's w/adjusters, ADS Piggyback rears, Toytec Shackles, Icon Rebound 17in wheels +25 offset, 35x12.50xr17 Nitto Ridge Grapplers. Miscellaneous: Tech 12 volts remote start, Tyger side steps, Color matched pro grille & bulge, Black handles off of SR5 Tundra
    Question for all you suspension guru's. Can you run an extended length shock (ADS, Kings, etc..) in the rear if all you have is a 3/4" to 1.5" shackle on the rear? Or does the lack of a new leaf kit with lift in it mean one should stay on standard length shock?
    Thanks in advance!
  2. Oct 29, 2019 at 3:39 PM
    Run the Toytec Boss shocks. They were designed for a 0 to 2 inch rear lift but now their site says 1 to 3 inch. Give them a call...they will help you and confirm.
  3. Oct 31, 2019 at 3:04 PM
    StrmTroop29
    StrmTroop29 New Member
    Anthony
    The toytec boss shocks are going to be for a minimum of a 1 inch of lift all the way up to 3. So if you put the shackles at 1.5 you are good to go.
  4. Nov 1, 2019 at 8:09 AM
    ctdomain
    Clint
    Went ahead and got in on the ADS group buy, went with standard length shocks for now. Once I have enough $$ i'll trade in for extended and grab a Deaver-U748 leaf pack, but for now I'm just going to run a toytec shackle in the rear to fix the ride height in the back.
