Rear shock help for 2" lift
Discussion in 'Suspension' started by ccam, Jun 22, 2018.
  1. Jun 22, 2018 at 10:15 AM
    ccam
    ccam [OP] New Member
    chris
    Fishers IN
    2011 Tundra Crewmax TRD
    1 in spacer lift on top of the coilovers and in rear, k&n cold air intake, toytec tunebcs coilovers up front, toytec boss 3in lift rear shocks, trd rear sway bar, straights from the cat. back (She purrs a little)
    I bought a 2011 tundra crewmax trd. stock suspension. The truck had a 2 in spacer in the front. I did not like the way the truck sat so I leveled the back end. Now the shocks are fully extended and the ride is rough as ever. I have been to the local 4 wheel shop and most of the rear shocks are designed for up to 1in lift or 3+. All I want to do is smooth out the ride. Any suggestions on which rear shocks to use for 2in lift. Should I add the rear sway bar?
  2. Jun 22, 2018 at 10:16 AM
    Which shocks do you have in the rear? Any blocks? Shackles?
  3. Jun 22, 2018 at 10:57 AM
    ccam
    chris
    Fishers IN
    My knowledge is limited but stock shocks, blocks in the back I believe shackles too?
  4. Jun 22, 2018 at 11:17 AM
    There are factory shackles, after market (adjustable) and different height blocks.
  5. Jun 22, 2018 at 11:19 AM
    ccam
    chris
    Fishers IN
    I was told to change the rears and leave the fronts as is.
  6. Jun 22, 2018 at 11:20 AM
