Rear seats no matching up on new Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by dan7365, Feb 18, 2019.
  1. Feb 18, 2019 at 11:42 AM
    dan7365
    dan7365 [OP] New Member
    I just purchased a new 2019 Tundra, Platinum Crew Max, a few days after I got it I noticed the rear seats are not matching up on the back part, between the passenger and middle seat. I attached a photo, please take a look and let me know if you know anything about this.
    Thank you
  2. Feb 18, 2019 at 11:46 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Welcome to the forum!!! Can you explain in detail a bit more? Perhaps a different view?
  3. Feb 18, 2019 at 11:51 AM
    dan7365
    Thanks for the response, the back part of the seats near the top are not lining up, if you look closely you'll see the passenger side seat sticks out about and inch, here's the same photo with the spot circled.
  4. Feb 18, 2019 at 12:04 PM
    Welcome from NY.
  5. Feb 18, 2019 at 12:05 PM
    tbrown
    tbrown 2017 CM FFV
    Nashville, TN
    2017 TRD Blazing Blue
    Magnuson Supercharger Kooks long tube headers King 3.0 remote reservoir w/ clockers front King 3.0 triple bypass remote reservoir rear Deaver Custom leaf Method 312 Corsa Exhaust w/ custom stainless bro’s resonator tip Custom HP tune Viair 400c Dual Onboard Headlight Revolution Stealth Bar Baja design XL 80 ditch lights on SDHQ Ditch brackets Victory 4x4 sliders and bed Molle RCI Skids C4 fabrication overland front bumper Smittybilt x2o 12k winch Toyo Open Country RT 37’s Icon Billet Delta UCA’s Nitro 5.29’s ARB Air locker front and rear Switch Pros Leitner Designs Bed Rack ICS Fab Dash Mount Expedition One Dual Swing Rear Bumper Viper remote start Rosen in headrest DVD players
    put a new sub box behind the seat, should fix it right up ;)
    and welcome from TN
    TRD15559 and KnuckleHD like this.
  6. Feb 18, 2019 at 12:05 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  7. Feb 18, 2019 at 12:10 PM
    GOLFNUT
    GOLFNUT New Member
    Dale
    2018 Tundra Platinum
    Those dont even look like the platinum seats. My 2018 platinum has the fancy stitching in the seats.
    Omohundro and Shark Bait like this.
  8. Feb 18, 2019 at 12:11 PM
    TXTundra2722
    2015 Black Tundra
    Welcome from TX
  9. Feb 18, 2019 at 12:15 PM
    Shark Bait
    Shark Bait Not new anymore
    David
    2019 Platinum
    Mine are stitched as well.
  10. Feb 18, 2019 at 12:20 PM
    dan7365
    Sorry, it's a Limited not a Platinum
  11. Feb 18, 2019 at 12:42 PM
    Shark Bait
    David
    2019 Platinum
    I was gonna say, the doors would be stitched too.
  12. Feb 20, 2019 at 8:44 PM
    matthew7899
    matthew7899 New Member
    Matthew
    2016 Toyota Tundra Platinum
    I think I saw another video where a guy noticed the gap between the back of the seats to the back wall was smaller which caused a rubbing sound...the way he fixed it was buy removing the seat that was closer to the back wall (the driver side in your pic) and put a spacer on the back mounts. This seems to be the same issue you're noticing. Here's the video.
  13. Feb 20, 2019 at 9:29 PM
    r1-superstar
    DB
    UTAH
    Check to make sure both sides of the rear seats are bolted in correctly.
