Rear rebuild or upgrade? Help!!
Discussion in '1st Gen Builds (2000-2006)' started by Zach4x4, Apr 9, 2017.
  1. Apr 9, 2017 at 4:28 PM
    Zach4x4
    Zach4x4 [OP] New Member
    Hello everyone,
    Yep, finally joined the Toyota Family and pretty much had this tundra dropped in my lap. Local Northern California gal needed to sell and I thought of it as an investment. 2000 trd 4x4 4.7 v8 automatic. Only 110k miles. But its been a rough road in these hills. Turn out that after a month of driving I need to replace the rear axle internal parts. Ill have the specs in a few hours when I get to work, where I left the paperwork from the shop. Maybe 411 x 309 gear ratio. Complete guess right now. $900 for the used parts. Or should I buy a new rear axle that is geared for both: some highway but mostly very hilly and gravel roads?
  2. Apr 9, 2017 at 4:38 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Could just buy lockers and 4.33 gears! Might run you a little more but since you're in need of a replacement...why the hell not??
  3. Apr 9, 2017 at 4:40 PM
    Zach4x4
    I have a
  4. Apr 9, 2017 at 4:42 PM
    Zach4x4
    Mechanic that is going to work on it soon so where should I buy these parts or what should I tell them to order if I stay in the $1200 range?
    Zmoody101 likes this.
  5. Apr 9, 2017 at 7:56 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Check out east coast gear supply for an exchange drop-in diff. You'll save a lot over the numbers you are throwing around, once your core is returned and credited.
    The gear ratio needs to remain the same for a 4x4, unless you regear both diffs. From what I could find, your truck should have 3.91 gears. Your rear diff is known as an 8.4", even though the ring gear measures 8 inches
    The advantage to regearing to a lower ratio (bigger number) is to accommodate larger tires - both correcting for the change in distance traveled per rotation, and the added torque required to accelerate heavier tires.
