Rear main seal … what else to do ?
Discussion in '2nd Gen Tundras (2007-2013)' started by Jason fisher, Aug 15, 2024.
  1. Aug 15, 2024 at 10:08 AM
    Jason fisher
    Jason fisher [OP] New Member
    Taking my 2011 Toyota hundred in on Monday, it is having its rear main seal done, 17 hours labor, $54 part, what else should I have them do while they are doing that??
    Jeff_1974 likes this.
  2. Aug 15, 2024 at 10:14 AM
    AZBoatHauler
    So.Arizona
    How many miles? Not much else going on in that area that I can think of. Upgraded motor mounts maybe but they probably won’t make it to you in time.
  3. Aug 15, 2024 at 11:29 AM
    Jason fisher
    330k km , it’s my work truck , so not pretty , but figured the $2900 was cheaper than a new truck
  4. Aug 15, 2024 at 2:37 PM
    Tundra Chief
    Tundra Chief New Member
    Wichita KS
    2021 SR5
    Transmission torque converter seal would be a thought. 10 minutes extra time plus the seal and ATF to replace what gets lost.
  5. Aug 15, 2024 at 2:53 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    damn. my rear main seal cost me $800 back in 2021
  6. Aug 15, 2024 at 6:42 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    Before you take your truck in try replacing the PCV valve a bad one will cause the crank case to have elevated pressure causing extra pressure on seals do an oil change replacing 1 quart of oil with a product called AT 205 reseal the product rejuvenates rubber seals it could save you a lot of money
