Rear main oil seal
Discussion in 'New Member Introductions' started by Nickaroo, Dec 11, 2024.
  1. Dec 11, 2024 at 7:17 AM
    Nickaroo
    Nickaroo [OP] New Member
    Hey guys, I have 2011 Rock warrior and just found out my rear main oil seal is leaking. I was wondering how common this is? I used to own a T-100 had almost 300k with no engine problems like this…..very disappointed with the Tundra.
  2. Dec 11, 2024 at 7:22 AM
    Rear mains will leak at some point. You didn’t say how many miles are on your truck. It’s a piece of rubber, it ages, it wears out. Pretty sure mine is leaking on my 2000 2UZ with 275k miles. It’s pretty mild, so just running high mileage oil to help keep it conditioned. May never fix it, if I have a reason to drop the trans or pull the motor (unlikely) I’ll address it then.
    AZBoatHauler likes this.
  3. Dec 11, 2024 at 7:26 AM
    Nickaroo
    Hi, thank you for responding so quickly, sorry to forgot the mileage.
    115k
  4. Dec 11, 2024 at 7:27 AM
    Nickaroo
    I was quoted $2,500 to fix.
  5. Dec 11, 2024 at 7:27 AM
    How much is it leaking?
  6. Dec 11, 2024 at 7:32 AM
    Nickaroo
    I just now found out about it.i have gravel driveway,I just put down some plywood to park over. 3 days ago. I haven’t noticed anything on the plywood yet. The bell housing is wet and so is the Tracy cross member.
  7. Dec 11, 2024 at 7:33 AM
    AZBoatHauler
    So.Arizona
    So it seeps after 14 years… what a piece of shit.
    FrenchToasty likes this.
  8. Dec 11, 2024 at 7:34 AM
    Nickaroo
  9. Dec 11, 2024 at 7:35 AM
    AZBoatHauler
    So.Arizona
    Probably dried out from sitting without use for extended periods.
  10. Dec 11, 2024 at 7:38 AM
    Nickaroo
    I drive it just about everyday
  11. Dec 11, 2024 at 7:39 AM
    Nickaroo
    I just got done with a 3k mile road trip….
  12. Dec 11, 2024 at 7:41 AM
    AZBoatHauler
    So.Arizona
    That’s almost 50% of your annual mileage. That was kind of my point - if you’d only put 3-4k miles on it through the year until then - that’s a lot of sitting.
    People on here tend to favor trucks driven 10k miles / year over one that’s was driven 2k miles / year because rubber dry rots.
  13. Dec 11, 2024 at 7:45 AM
    Nickaroo
    Not really. I’m retired I don’t go far.
  14. Dec 11, 2024 at 7:49 AM
    If it doesn't drip off the vehicle, it's minor in nature for me. Also, likely the extended periods at cruising speed that exacerbated what is probably a minor leak. Aside from labor to have it done, it's a $15 or so fix. If I were quoted $2500 to fix it, I would evaluate strongly whether it need to be fixed at this point or not. I would look into alternatives to slow the bleed so to speak (not snake oil, legit seal conditioners). I had a 1984 S-10 with the 2.8 V6 that had a really bad real main seal leak. Didn't leak driving around town at lower engine loads, but blew oil like crazy on the highway to the tune of 4qts per tank of gas. I ran 20w50 and some stop leak and it stopped leaking all together on that highway trip. I ran 5W30 in my 5.7 and would probably be on high mileage oil at your mileage. Both would slow the leak.
  15. Dec 11, 2024 at 8:21 AM
    AZBoatHauler
    So.Arizona
  16. Dec 11, 2024 at 5:52 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! As others have alluded to, with a truck that old, an oil leak that minor is not unexpected, and if you're losing less than a quart between oil changes, I would not worry about it at all.
  17. Dec 11, 2024 at 7:49 PM
    Welcome from NY.
