Rear light wiring harness
Discussion in '2.5 Gen Tundras (2014-2021)' started by bajatundra53, Sep 27, 2019.
  1. Sep 27, 2019 at 5:32 PM
    bajatundra53
    bajatundra53 [OP] New Member
    The dogs chased a chipmunk up into the spare tire well and then proceeded to chew through the wiring leading up tho the left tail lights right behind the spare tire (grrr- dam dogs! ) so I need to replace the harness section leading up to the the Left bulb harness - too many wires (8?) to splice . Anyone know a part number ? - it's 2017. Thanks
  2. Sep 27, 2019 at 6:27 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Ask @Roman. He's the parts guru. Fix you up no problem. Try sending him a PM.
  3. Sep 30, 2019 at 10:51 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I would definitely work on fixing what you have. The harness for the taillights are not available separately from the whole harness that runs to the back of the truck. The 2nd gens had a separate harness for the taillights, but the 3rd gens do not.
