Rear leak
Discussion in 'General Tundra Discussion' started by fritzy, May 18, 2019.
  1. May 18, 2019 at 1:23 PM
    fritzy
    fritzy [OP] New Member
    2007 Tundra, 4.7 liter, SR5 regular cab, 80k miles. Leak under rear end of truck, right in center. Also brakes have to be stood on to work and brake light is on. Can you tell me what I'm looking at and guessitimate of cost to fix? Thanks.
  2. May 18, 2019 at 1:28 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Leaking hose?? Hope it’s an easy peasy fix.
  3. May 18, 2019 at 1:28 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome from TX!
    Guessing differential leaking and brakes need overhauling. $500-5000 range........
  4. May 18, 2019 at 2:01 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Is the fluid brake fluid? Is the brake fluid low?
    What part of the world are you in? The salt and rust part? Could be a rusted out steel brake line. Could be all sorts of things. Pics and / or more information would help.
  5. May 18, 2019 at 2:22 PM
    He lives in the salt belt, so hopefully the rear diff is just a 3rd member gasket leak. To complete that job, the third member has to come out. 4 hours labor.
    If the the axle has rusted through, I would get one out of a junkyard and swap it out.
    The brakes on the Tundra are impressive. If you need to stand on them to stop, there’s some serious problems. Sounds like some stuck calipers. If the rust isn’t to bad, you can rebuild them. Pretty easy.
    Trooper2 likes this.
  6. May 18, 2019 at 2:37 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Welcome! Can’t help you. My rear leaks all the time.
