Rear heat when it should be A/C - Center console gets very hot
Discussion in '2.5 Gen Tundras (2014-2021)' started by JamesRiverDog, Jan 26, 2025.
  1. Jan 26, 2025 at 5:26 PM
    JamesRiverDog
    JamesRiverDog [OP] New Member
    2014 Tundra Crew Max - Limited
    I have a 2014 Tundra Crew Max Limited (250k+ miles) with air control issues. We didn't notice the issue until the summer, and while it isn't a problem now, it will happen in several months.
    Nearly 75% of the time, when we have the AC on (or selected automatically through climate control), very hot air comes out of the rear vents on the console. One thing is for sure: the dogs notice it. What we do is shut the vents so as not to overheat the dogs, and then the center console (inside and cup holders) gets extremely hot. I joke that we could probably cook a roast in the console during a long trip. If you have an ice-cold fountain drink in the front cup holder, it will be warm within 20 minutes.
    What is strange is that it doesn't happen all the time, and I cannot identify what combinations of settings cause it to happen.
    It is probably worth noting that I had the dealership replace a loud fan motor a couple of years ago.
    Any thoughts before I take it back to the shop and spend a fortune?
  2. Jan 30, 2025 at 11:36 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Hard to figure your complete solution as it could range anywhere from a malfunctioning blend door to needing a freon recharge or a bad expansion valve. I'm no expert on this but figured I'd give you something to think about if you decide to tackle it yourself.
    Or if you already took it to the dealership, you could post what the fix was for future reference.
  3. Jan 30, 2025 at 12:52 PM
    There isn't a blend door between the front and rear I don't beleive. I added rear AC to my Double Cab and it was just adding a duct that taps off of the front, a new rear console panel, and the vents.
    g6t9ed[QUOTED] likes this.
  4. Jan 30, 2025 at 1:40 PM
    g6t9ed
    Ah, then my bad. Figured there might be but you could be right.
  5. Feb 4, 2025 at 1:56 PM
    DeepBushCaboose
    DeepBushCaboose New Member
    Michael
    Austin, TX.
    2020 Black Platinum Tundra
    I've had somewhat similar symptoms recently. Had it diagnosed as a bad expansion valve. It's being replace tomorrow. When it first started it seemed to be intermittently warm.
