Rear hand brake install pictures
Discussion in '2.5 Gen Tundras (2014-2021)' started by TTracer, Jan 8, 2022.
  1. Jan 8, 2022 at 10:12 PM
    TTracer
    TTracer [OP] New Member
    Daniel
    California
    2014 black tundra LT
    -Long travel -King Shocks all around with valving -paddle shifters -cutting brake with wilwood brakes -dap tune - custom front bumper -switch pros - gps - race radio -custom 3rd brake light - ultra wheel-
    0449AF1E-7D42-4C13-AB9D-40831472972E.jpg F4D87AD0-2D5F-4210-829C-8673DC7E69AC.jpg BD3FD972-DF8A-49B9-B863-0E4B57504217.jpg AE690F36-F5F1-4EBB-82D0-D44FFDA21C6D.jpg F31A98C7-8B1F-4DBE-A354-1188241B268F.jpg 37983749-B97F-46D6-94CF-71D563DE1426.jpg A3944976-F322-4328-8BF0-D6C581D5CD55.jpg 9FA6B030-9431-4936-8EC7-80E6E7B182FB.jpg 649F67B6-4B24-4F3F-AF8D-583A87F628AD.jpg 2E693A36-93E8-4577-BC21-335CA6770D19.jpg Hand brake install “ruff brake down”take axles out press out brake cover plate for cutting make custom mounts for new calipers weld it up replace all axle seals and bearings don’t want a problem later install cutting brake handle and master cylinder plumb back calipers to handle bleed and drift
    pvn.beluga, KevinK, papasmurf and 2 others like this.
  2. Jan 9, 2022 at 10:16 AM
    Never seen anyone set their cutting brakes up like this. Interesting.
    Keep us posted how you like them on your desert bomber.
    TTracer[OP] likes this.
  3. Jan 9, 2022 at 10:20 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    What is a cutting brake?? Never have heard of or seen one before now? Very cool that you can do all that though!!:)
    Found out what it is,, I suppose I might have to see one in action???
  4. Jan 9, 2022 at 11:09 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    We need more context to understand why you’re doing this? If this were a drag setup, I would understand. But nobody is running down the strip routinely with King shocks. So that’s not what’s going on.
    Black@Blue19 likes this.
  5. Jan 9, 2022 at 11:40 AM
    art64
    art64 New Member
    In off road, it allows the vehicle to drift to the left or right. Cutting brakes lock up the left or right rear wheel
    It can also aid in traction by locking the wheel that is spinning when that wheel is suspended in the air. The power is then transferred to the other wheel.
    https://www.youtube.com/watch?v=lvze-dtAbhU
    This is just one of the applications.
    15whtrd, snivilous and Black@Blue19 like this.
  6. Jan 9, 2022 at 12:20 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    It's the same thing as drift cars have, pull the handle to lock up the rear and get it to slide or if you have front dig you can drag the rear to pivot around easier. I wouldn't call his setup cutting brakes necessarily, cutting brakes usually mean independent lockup (like brake the back left to turn tighter to the left, not both at the same time), though all that's missing is the extra plumbing and another lever to engage that. Some vehicles like comp crawlers even have cutting brakes for the front, so you can have just the front right or the back left or any combination lock up so you can maneuver tighter or manually direct power.
    I think it's dope. I have that same handle for my buggy! But I was going to plumb it inline with the stock brakes since I'm lazy, the dual calipers is the fancy way to go though.
    KevinK and TTracer[OP] like this.
  7. Jan 9, 2022 at 1:42 PM
    TTracer
    Daniel
    California
    So for re running in the desert there are lots of tight turns this cutting brake / hand brake allows me to stop both back wheels and pitch the truck into a drift left or right at speed to get around the tight turns
  8. Jan 9, 2022 at 1:47 PM
    TTracer
    Daniel
    California
    I was going to do it inline but the abs in our trucks suck and would most likely throw a code on the dash independently plumbed the truck doesn’t know it’s there
  9. Jan 9, 2022 at 1:56 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    The only thing I would worry about is the electronic LSD possibly interfering when it detects one wheel spinning and the other not and limiting engine power or braking the spinning wheel to compensate. FWIW, I ran new lines and bypassed the ABS on my 2012 Tacoma and didn't get any error codes.
  10. Jan 11, 2022 at 1:51 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Removing the ABS 1 fuse solves all of this. It kills traction control and ABS 100%.
    Do not use the truck on public roads with the ABS 1 fuse pulled.
    @TTracer what year is yours? I can see it’s at least a 2014. Our 2014 enters ice mode way too easily when it’s upset at high speed off road. That’s what led me to searching for how to disable traction control completely. On hardback or washboard, trying to brake from high speed just confuses the abs module and it seems to assume you’re on ice. The brake pedal goes solid and you get about 10% brake power. The abs 1 fuse pull gets rid of that and keeps me from killing myself or friends by overshooting a braking zone.
    Nice hoon handle execution. :burnrubber:
  11. Jan 11, 2022 at 9:49 PM
    TTracer
    Daniel
    California
    ya I wired a 60 amp relay to the abs and put it on a switch for off road makes it easy to turn everything off
    KevinK[QUOTED] likes this.
  12. Jan 12, 2022 at 9:43 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    Sweet!
  13. Jan 12, 2022 at 3:18 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Oooooh I likey! With a hand brake like that I'd be able to make super sharp turns like on switchbacks - on dirt trails of course. Check out Trail Mater starting at 4:19 on this video. He brakes the rear, then uses his front lockers to pivot the truck.
    https://www.youtube.com/watch?v=JKzolvcQ_Xw
  14. Jan 12, 2022 at 3:28 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    That was some ass clenching driving. That recovery team has insane skills and a bad ass tow truck. A joy to watch.
    2mchfun and Cruzer[QUOTED] like this.
  15. Jan 12, 2022 at 5:00 PM
    snivilous
    SW UT
    Time for an atlas after you get beadlocks :D
  16. Jan 12, 2022 at 5:07 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I wish. They don't make it for gen2+ :(
  17. Jan 12, 2022 at 5:26 PM
    snivilous
    SW UT
    Just an adapter plate away :D ....maybe....
    KevinK and HulkSmurf14 like this.
  18. Jan 13, 2022 at 6:10 AM
    KevinK
    Tundras to Sedona
    does the relay reset with ignition cycles or do you have to turn it back on manually? I thought about just putting a momentary switch in-line with the fuse. It only takes a momentary disruption for the system to fail and requires an ignition cycle to re-run the self test and turn back on.
    TTracer[QUOTED][OP] likes this.
  19. Jan 13, 2022 at 12:35 PM
    TTracer
    Daniel
    California
    YOU MUST USE A RELAY or when the abs Tripp’s the switch will melt FYI been there done that
    I press the switch everything turns off turn switch again then turn off truck turn on truck back to normal
  20. Jan 14, 2022 at 8:59 PM
    KevinK
    Tundras to Sedona
    Oh shit, thanks for the tip! Ha, I woulda melted my shit.
  21. May 2, 2022 at 3:22 PM
    2017_Tundra_AZ
    2017_Tundra_AZ New Member
    Dang! I wish I would have know this early. I have been dealing with almost dying from ABS while offroading for years. Is there any risk of an airbag going off during this process? Idk why, but someone told me that.
  22. May 2, 2022 at 4:50 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    All I’ve got to say is that looks freaking sweet to have a usable hand brake in those situations. Definitely for the deserts and sending it!!!
  23. May 2, 2022 at 6:29 PM
    2017_Tundra_AZ
    Dude this is awesome!! I have always wanted to do something like that. I use to have turning brakes in my sandrail and it was a blast.
