Rear frame bushings?
Discussion in 'Suspension' started by Tundra_361, Jan 10, 2019.
  1. Jan 10, 2019 at 5:26 PM
    Tundra_361
    Tundra_361 [OP] New Member
    Victor
    2019 Black 1794 4x4
    Hey fellas. I’m looking to replace my driver side “rear frame bushing and sleeve” any ideas on where to buy them from besides the dealer? Dealer wants $40+ for just the sleeve and $28 for the bushing. Thanks
  2. Jan 10, 2019 at 5:43 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Not sure what bushing you mean. Leaf spring bushing?
  3. Jan 10, 2019 at 5:47 PM
    AZTundra
    Paul
    Phoenix, AZ
    Thinking Leaf Spring Bushing as well. Need more info to help. Why is it needing to be replaced? If needing the Leaf Spring Bushings I'd consult with @Coachbuilder1 for an improvement over stock.
  4. Jan 10, 2019 at 6:27 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    The frame bushing. Not the leaf spring bushings. The top bolt of our rear shackle goes threw the frame where the bushings are. Those bushings
  5. Jan 10, 2019 at 6:40 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Well, I replaced my CB +2 shackles and went back to stock shackles. When I was putting 1 of the 19 mm bolts back in the frame, it was pushing the sleeve out of the bushings. I took the sleeve out and had to force the bolt threw the sleeve.
    So now the sleeve won’t move as it should when the suspension is cycling. Basically the bolt is stuck in the sleeve or the sleeve is stuck on the bolt. However you want to look at it. Also there was white residue on the inside of the bushings. I thought it was some kind of lubricant but it was almost like powder.
  6. Jan 10, 2019 at 7:12 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Sorry, Total chaos and Camburg are the only ideas I have other than OEM.
  7. Jan 10, 2019 at 7:39 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Ok so they make replacement bushings for the fram? I’ll look but they didn’t pop up when googling
  8. Jan 10, 2019 at 9:26 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Also, there's a vendor on this site @eccracer104, Mike, he might be able to help ya.
    eccracer104 likes this.
  9. Jan 10, 2019 at 10:44 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Ok, thanks
  10. Jun 16, 2022 at 6:15 AM
    biggsy
    biggsy New Member
    Warren
    2010 Tundra DC Rock Warrior
    Hello, I am replacing my leaf springs this weekend and am thinking about replacing the same frame bushing. Any success in finding a replacement ?
  11. Jun 19, 2022 at 11:24 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Like everyone is saying, I think you're talking about the leaf spring bushing if you're referring to your shackles and the 19mm bolt that goes through to hold the shackle in place to the frame.
    When you swapped over to CB shackles, did you keep OE bushings in leaf?
