Rear end went out.... ugh
Discussion in '1st Gen Tundras (2000-2006)' started by ToxicDC5, Mar 5, 2017.
  1. Mar 5, 2017 at 6:00 AM
    ToxicDC5
    ToxicDC5 [OP] New Member
    Roger
    05 white DC5
    Leveling kit, 285/70/17 MT's
    So. I've had an issue with the rear for a while now. When slowing down hard on the brakes, after I let off and push the gas back down, the rear end would thump. Like a loud clunk. But then would be fine after. So I have always braked easy and it hasn't occured.
    This morning I had two deer run out in front of me and had to get on the brakes hard. The truck revved high and sounded like it was in neutral, then kinda slammed into gear it seemed. But left me sitting still. I put it in 4x4 and creeped the 2 miles a had to get it home at about .000001 MPH. Lol.
    While in 4x4, the rear end made a steady thumping sound, and if I pushed the gas it got louder and harder. The U joints are fine, and the rear end has no leakage... I'm assuming the ring and pinion gears are gone. Anyone else had a reare end issue similar???
  2. Mar 5, 2017 at 6:37 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Strange that it would do that after braking heard. Rear diff shouldn't be affected by braking.
    joem1cha3l likes this.
  3. Mar 5, 2017 at 6:38 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    This.....
  4. Mar 5, 2017 at 8:05 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Puzzling. Back In the day, with my Gen1, I had the front dif spider gears completely shred...and I mean completely. Had ZERO indication that anything was wrong, except that my mikes per tank went up almost 30-40 miles!! No sounds. No binding.
    Also, no 4wd.
    Took to dealer and they drained the front dif, only to discover chunks of metal falling out with the oil. After that, and also discovering the extended warranty explicitly did not cover the spider gears, the front end would bind up. A week later i installed a junkyard front end built up with a Powertrax locker. Put a locker in the rear too. Ended up going almost 100k before I sold the old girl...no issues.
    I would get that thing on a lift, drain the dif and borescope to see if there are any issues. On a side note, tearing apart a rear end on the Gen 1 was easy as pie. Rear axles pull out easy and the third member dif unit pulls out nice and easy.
    Good luck
    ToxicDC5[OP] and Warreng like this.
  5. Mar 5, 2017 at 8:06 AM
    Bear
    Bear
    Custer, SD
    Also, you may want to check the rear driveshaft. When's the last time you greased it up? Is it leaking? Pumping some grease into the shaft splines may reduced some "noise"
  6. Mar 5, 2017 at 6:21 PM
    ToxicDC5
    Roger
    05 white DC5
    The drives shaft and rear end were as solid as could be. Never ever had a leak or any problems what soever. This truck (not bragging) was in tip top shape. Gonna just go ahead and replace the whole rear end I believe. I've had two different mechanics (one is a certified toyota tech) come look at it today and both said the same. Rear is gone.
  7. Mar 5, 2017 at 6:24 PM
    ToxicDC5
    Roger
    05 white DC5
  8. Mar 5, 2017 at 6:25 PM
    ToxicDC5
    Roger
    05 white DC5
    Poor thing lol
  9. Mar 5, 2017 at 6:27 PM
    ToxicDC5
    Roger
    05 white DC5
    Yeah I thought the same thing. Puzzling
