Rear End Thud
Discussion in '2.5 Gen Tundras (2014-2021)' started by JohnH, Jun 5, 2018.
  1. Jun 5, 2018 at 6:08 AM
    JohnH
    JohnH [OP] From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    Hello all,
    I searched the forum and didn’t find exactly what I’m looking for so I will post the question here.
    Since new, my 2017 4WD double cab has had a rear end noise that I can’t quite identify. I know I have recently gone through some suspension changes and I had hoped that this third would go away… But it didn’t. It’s a solid noise and it sounds like a muffled metal on metal.
    Whenever I go over a small to medium sized bump I can hear it from the rear end. I have checked the spare it seems to be pretty solid. I shook my exhaust and there seems to be no metal to metal contact.
    The only other thing I thought of was they didn’t tighten down my bed bolts when they reinstalled them after my spray in liner. I’ll obviously check that.
    Ideas?
  2. Jun 5, 2018 at 10:57 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  3. Jun 5, 2018 at 12:10 PM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    I have the same truck and the same issue. I also checked all the things you did with the same results. I can reproduce the sound by pulling into my driveway and hitting the bump just right. No idea what it is.
  4. Jun 5, 2018 at 12:25 PM
    Warreng
    Warreng New Member
    My tailgate makes a clunk over bumps.
  5. Jun 5, 2018 at 12:42 PM
    JohnH
    JohnH [OP] From PA
    Pennsylvania
    Nice to know. I’ll try and recreate it.
    Thanks
  6. Jun 5, 2018 at 12:43 PM
    JohnH
    JohnH [OP] From PA
    Pennsylvania
    It’s annoying and I think we’ll figure it out eventually.
    Thanks
  7. Jun 5, 2018 at 1:07 PM
    Njmike13
    Njmike13 New Member
    2021 PRO Lunar Rock
    Good info. I'll have someone sit in the bed while I pull in the driveway and see if that's it.
  8. Jun 5, 2018 at 2:51 PM
    TheBeast The Beach
    tighten bed bolts, check the bed frame where the bed sits on.
