Rear end replacement 2003 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Lisamcdon73, Oct 31, 2022.
  1. Oct 31, 2022 at 6:53 PM
    Lisamcdon73
    Lisamcdon73 [OP] New Member
    Lisa
    2003 Toyota tundra sr5
    I have a 2003 Toyota tundra 4.7 v8 4wd that needs the rear end replaced and I'm needing to know what other vehicles have compatibility for this.
  2. Oct 31, 2022 at 7:05 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    What cab configuration do you have. Regular cab/access cab or a double cab?
    shifty` likes this.
  3. Nov 1, 2022 at 12:16 AM
    Lisamcdon73
    Lisa
    Access cab
  4. Nov 1, 2022 at 2:12 AM
    NickB_01TRD
    Nick
    KY
    You need to find another access cab or regular cab with the same gear ratio. Are you replacing due to rust or something else? If rust you can use one off any access/regular cab and just swap your differential over. If your differential is bad you'll need to find the same gear ratio since it is 4wheel drive.
    Double cab axles are too wide and sequoia axles have coil spring suspension and would require very extensive modification.
    I'm not sure about Tacoma axles but I think there may be some differences.
    shifty` likes this.
