Rear End issues
Discussion in 'Recovery & Gear' started by Tomas, Aug 3, 2019.
  1. Aug 3, 2019 at 11:51 AM
    Tomas
    Tomas [OP] New Member
    Tom
    Red, 2015 Tundra TRD
    none
    I appreciate any advice you can give. My 2015 Tundra TRD has 157,000 miles on it, I replaced the tires recently and started hearing a loud noise - "road noise" - I attributed to the new set of tires. The noise was getting so bad, I had to replace these tires after about 1 month. Took it in and I was informed the noise isn't the tires, but the read end! Here's my question: Is this a known issue with Toyota? I've been quoted $3,000.00 to replace the entire rear end with a rebuilt rather than used. In all of my years driving, I've never heard of the need to replace the rear end..... Any advice on where to shop for a (refurbished) rear end, or general cost comparison to what I've been quoted would be greatly appreciated!
  2. Aug 3, 2019 at 11:52 AM
    Tomas
    Tom
    none
    I'm in Arizona BTW......
  3. Aug 15, 2019 at 6:03 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I don't think it's a common issue, but 157k on a 2015 indicates to me that either you drove the piss out of that truck or someone else did..
    I would find a 3rd member at a junk yard and do it yourself. It's easy..
    ColoradoTJ and Black Wolf like this.
  4. Aug 15, 2019 at 6:15 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    If the increased road noise doesn’t change with throttle changes, ie, coast to accell, then it’s more likely to just be a rear wheel bearing or two, the shop is trying to pad their retirement fund at your expense. Get another opinion.
    ColoradoTJ and Watt maker like this.
  5. Aug 15, 2019 at 6:46 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Hopefully it is the wheel bearings, a lot easier and cheaper.
    Watt maker likes this.
