Rear driver door not locking
Discussion in '2nd Gen Tundras (2007-2013)' started by 08trd, Apr 3, 2017.
  1. Apr 3, 2017 at 9:30 AM
    08trd
    08trd [OP] New Member
    2008 Red Tundra SR5 TRD
    K&N CIA, Flowmaster American Thunder Exhaust, Toyota Step Bars.
    So I just bought an 08 sr5 DC and noticed that it would not beep upon lock. After reading up i found that it will not beep if one of the doors are not locking. The rear driver side door does not lock or unlock via remote or lock/unlock switch inside cab. I took off the door panel and it looked like all the cables were connected. I removed a couple of the wiring harnesses and re inserted them. It still does not work properly. What should I be looking at replacing to fix it? Control module? Other electrical part? Thanks.
  2. Apr 3, 2017 at 10:12 AM
    15whtrd
    15whtrd Mr. Blonde
    Pretty sure that should be the doorlock actuator. I've read that they are prone to fail over time.
    NewImprovedRon and Law323 like this.
  3. Apr 3, 2017 at 11:50 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I agree, door actuator. I've had to do a couple on my 95 4Runner. Not to hard but they're not cheap.
  4. Apr 3, 2017 at 2:01 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    the actuator is part of the door latch
  5. Apr 3, 2017 at 2:25 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    On the 4Runner they were an electric actuator that just controls the lock.
    They'd work fine manually and w the key, just not with power buttons. They were about $90 a piece.
    08trd[OP] likes this.
  6. Apr 3, 2017 at 4:59 PM
    08trd
    Yep that's my issue.
  7. Apr 3, 2017 at 5:13 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Hardest part of the job was removing door panel without breaking any little fasteners. If you don't have one pick up one of those body panel tools. You can vet a cheap plastic one for under $10
  8. Apr 3, 2017 at 5:49 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Did you get it figured out or do you still need help?
    NewImprovedRon likes this.
  9. Apr 3, 2017 at 6:24 PM
    08trd
    Well I opened the door panel and all that crap. I still have to order the part. I've only done a quick search but found one for $60. I'll look more into in in an hour or so when I get out of class.
  10. Apr 3, 2017 at 6:25 PM
    08trd
    Yeah I have one but it wasn't with me at my fiancées place so I just jerked it off like I usually do. Only broke the black one at the top but I have more of those from my old Tundra.
  11. Apr 3, 2017 at 6:26 PM
    Nor7
    Take a closer look through the forum. I believe I've seen a thread where someone replaced the motor in the actuator instead of replacing the entire unit. It was a lot cheaper.
    smmpm2012 and 15whtrd like this.
  12. Apr 3, 2017 at 7:09 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    That's great advice. I never even thought of looking for just the motors.
    Next time.
  13. Apr 3, 2017 at 7:26 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Also, the Lock/Unlock beep can be turned off / on under custom settings using Toyota Techstream. The absence of the beep does not necessarily mean there is a malfunction.
    You can also make it unlock all doors with one push of the button.
  14. Apr 3, 2017 at 7:45 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  15. Apr 10, 2017 at 10:17 PM
    08trd
    Alright. So upon reading the other forums, I guess I still have to modify the new motors or the worm gear. I think I read that the door wont shut without the actuator so Ill probably have to do this all in one shot. It will be a few weeks before I have that kind of time :(
