Rear door handle issue
Discussion in '3rd Gen Tundras (2022+)' started by 57Willys, Jun 22, 2022.
  1. Jun 22, 2022 at 10:58 AM
    57Willys
    57Willys [OP] New Member
    Blue 2022 Tundra Platinum
    My driver’s side rear door handle literally came off in my hand when opening the door. I was able to slip it back in place and use the door, but I have to open it very gently or it will pop out again. Obviously a warranty issue.
    Anyone else had this problem?
  2. Jun 22, 2022 at 11:02 AM
    Taco-Spike
    Two Trucks
  3. Jun 23, 2022 at 11:31 AM
    Troa
    Troa I blue it again.......
    Nomad
    2022 Blueprint Limited
    It sounds like the clip that holds the handle in place has come undone. It should be a pretty easy fix if you're not into waiting for hours at the dealer. Just remove the door card, reach into the door, and re-latch the white clip that pivots into place to lock the door handle to the door. Without that clip locked the handle will work, but it will be able to come on/off easily.
    If you watch some install videos on how to replace your chrome handles with color matched ones you'll see what I'm talking about
