Rear Differential Nut
Discussion in 'General Tundra Discussion' started by JOEC, Jul 20, 2018.
  1. Jul 20, 2018 at 5:11 PM
    JOEC
    JOEC [OP] New Member
    Joe
    2007 tundra crew max
    Ok I'm no pro but trying to replace the rear differential seal on my 2007 Tundra. Having trouble removing the differential nut. It looks like the nut is locked or peened into an indent in the shaft. Anyone know if thats the case and how to handle it?
  2. Jul 20, 2018 at 6:56 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Not sure if you’re talking about the fill or drain or ?
  3. Jul 20, 2018 at 7:02 PM
    JOEC
    Joe
    The nut behind the drive shaft to remove the seal
  4. Jul 22, 2018 at 2:04 AM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    the nut is staked. there are special chisels for undoing this but you should be able to do it with a cross cut chisel
