Rear diff shavings found at fluid change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra18overland, Sep 18, 2021.
  1. Sep 18, 2021 at 1:37 PM
    Tundra18overland
    Tundra18overland [OP] Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Found a good amount of shavings while changing rear diff fluid today. Truck has 35k. I don’t tow very often and when I do its a utility trailer and lawn mower. Truck has been driving and shifting fine. Has anyone had this much shavings before?
    Wallygator likes this.
  2. Sep 18, 2021 at 1:50 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Ouch.. that is way more than I have ever seen on any of my Toyotas. I'd be taking it to the dealer..
    HulkSmurf14 likes this.
  3. Sep 18, 2021 at 1:50 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Yep, especially on the very first change, there is lots of gunk and shavings.
    But hard for me to tell if that is a chunk or just sludge down at the bottom , if a chunk, that is pretty big piece.
  4. Sep 18, 2021 at 2:13 PM
    Tundra18overland
    Jesse
    GA
    what is the dealership going to do though? Realistically
  5. Sep 18, 2021 at 2:24 PM
    Backslider
    Tooele, UT
    You should have a warranty, no? At a minimum, they can record the incident which may help if you experience further problems.
    I mean, the same could be asked about posting here. What's that going to do for you?
    GODZILLA, MEWaters, RavingOx and 4 others like this.
  6. Sep 18, 2021 at 2:52 PM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Other than that one big chunk, that looks like the heavy side of normal for the first change.
    AZBoatHauler and Uhhhh.... like this.
  7. Sep 18, 2021 at 2:58 PM
    Corrosivetendency
    Corrosivetendency New Member
    Nate
    2016 plain-jane d-cab
    Mine looked about the same at 70k miles when I bought it. Scared me but read up that this isn't rare.
  8. Sep 18, 2021 at 3:02 PM
    AZBoatHauler
    So.Arizona
    If your diff blows up at 100k you’ll be glad you took it in and had it documented.
  9. Sep 18, 2021 at 3:50 PM
    Tundra18overland
    Jesse
    GA
    i didn’t mean to be dismissive. Yes I imagine it’s covered under 60k powertrain, but if there’s no active issue I don’t see them doing anything, but I understand getting it documented.
    I got a better pic of the large piece. Appears to be a flat strip, not a 3D chunk.
  10. Sep 18, 2021 at 3:52 PM
    frichco228
    ah, much better, at least in my option. It seemed like a huge solid chunk before. Let toyota know and document it, double check there is no issue, but I dont think that looks too abnormal.
  11. Sep 18, 2021 at 4:04 PM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Lol
  12. Sep 18, 2021 at 4:27 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I probably say just take it in just for it to be documented. I did mine at 50k it had shavings but not like that strip of metal
    Tundra18overland[OP] likes this.
  13. Sep 18, 2021 at 5:15 PM
    Tundra18overland
    Jesse
    GA
    Thanks everyone for your input. Not going to stress it, we’ll see how it looks in another 15k.
  14. Sep 18, 2021 at 5:35 PM
    Punisher29073
    Punisher29073 New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    This was mine at 40k.
  15. Sep 18, 2021 at 5:38 PM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Is it magnetic ? Either way, it wouldn't bother me.
  16. Sep 18, 2021 at 6:05 PM
    Tundra18overland
    Jesse
    GA
    Yeah that large piece was on the magnetic drain bolt
  17. Sep 18, 2021 at 6:14 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I am going on a 3+k drive and I will be changing my diff oil out at around 15k just for shits and giggles. I am now curious as to what I find. I also not doing the 10k oil changes like Toyota wants. Doing one myself and the free one at the dealer. And they are not touching my wheels EVER AGAIN. They put like a torque multiplier when they rotate my wheels.
  18. Sep 18, 2021 at 6:16 PM
    Tundra18overland
    Jesse
    GA
    They definitely over tighten everything. It’s obnoxious. I Nearly broke my oil filter housing last oil change cause they over tightened it so bad. I’m curious to see what your diff plug looks like at 15k as well.
  19. Sep 18, 2021 at 6:20 PM
    pursuit2550
    I bought the aluminum filter housing just because of that reason. I had it in my last tundra and have the special tool for it. It’s pretty badass. Sometimes I don’t even want to go to get the free oil change but it’s free and I paid for it. Sneaky Toyota tells you free oil and tire rotation for x amount but the sticker clearly shows it as a charge.
  20. Sep 18, 2021 at 6:21 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    If it’s not making noise and it has normal backlash, they won’t do a thing. Shavings are normal for a broken in diff. Change the fluid and check it again in 10k. If you still have a lot of shavings, I would then bring it in.
    The ring and pinion essentially polish each other during break in. The metal has to go somewhere. This is why there is a magnetic in the differential.
  21. Sep 18, 2021 at 6:26 PM
    pursuit2550
    This. Also cheap insurance to changing out the trans fluid more often. Especially on the newer tundras without the trans cooler like mines. I will probably do it at 30k. And then do a fluid and filter at 60k. Truck has to last because the 22 are appealing and probably $$$.
  22. Sep 18, 2021 at 6:28 PM
    That's just from manufacturing. Like others have said, you could take the pieces into the dealership and have it documented. I wouldn't worry about it...but I have seen a lot worse on here. Wish toyota would do a better job of cleaning out the differentials after machining has been completed.
  23. Sep 18, 2021 at 6:31 PM
    pursuit2550
    Wonder if it machining or from break in. Since the gears have to be shimmed, I wonder if some do a better job than others. Or they weren’t ocd when they shimmed it.
  24. Sep 18, 2021 at 6:38 PM
    Could be from both, but these look like machining shavings. It would be cool to go over to Marion Arkansas to the plant to see the whole operation.
    pursuit2550[QUOTED] likes this.
  25. Sep 18, 2021 at 6:39 PM
    crewmaxlmt
    scott
    It’s from the break in but it is also just the nature of the beast. The gears are made from 8620 steel and heat treated via carburizing. This heat treatment leaves scale on the surface of the steel since they are effectively pumping carbon into the surface. During break in, the hardened gears polish each other and you get a lot of slag that sticks to the magnet. The larger pieces are burrs that did not burn off in heat treatment.
    A polishing procedure would do away with much of this but that costs money. If they are not going to give me a transmission cooler there is no way they are polishing my gears.
    2mchfun, classiccat, rockmup and 5 others like this.
  26. Sep 18, 2021 at 6:47 PM
    Tundra18overland
    Jesse
    GA
    if I knew what i knew now I woulda done it at 10k when i got the truck with 10k. Thanks
  27. Sep 18, 2021 at 6:48 PM
    Tundra18overland
    Jesse
    GA
    Thanks man!! We’ll see what It looks like next time. I’ll post a pic again in 10-15k on this thread if I remember.
  28. Sep 18, 2021 at 6:51 PM
    crewmaxlmt
    scott
    I would love to see the difference between an OEM operation and an aftermarket operation.
    I spent one day at IMTS in Chicago to look at a machine with my dad before we bought it. It would take a whole week to see the show. It’s that big in Chicago. I am certain that they would have a section dedicated to gears. I feel like most of the guys here would love it.
  29. Sep 18, 2021 at 6:57 PM
    This is when I would be worried.
    I personally have never seen any shavings like any image on this thread. Then again I also follow break in procedures to a tee as well.
  30. Sep 18, 2021 at 7:02 PM
    I have seen the aftermarket when my Solid Industries custom axle was built. The axle tubes are machined for a tight fit into the axle housing, pressed in and welded. The C's were pressed on and clocked. They cleaned out the tubes and housing. Pretty amazing what came out.
