Rear Diff Question
Discussion in '1st Gen Tundras (2000-2006)' started by fudozen, Aug 28, 2018.
  1. Aug 28, 2018 at 2:26 PM
    fudozen
    fudozen [OP] New Member
    Shawn
    2000 Tundra Access Cab, 2wd
    I have a leaking Rear Diff housing that needs to be replaced. The 3rd member may not be good anymore due to rust. This is on a 2000 Access Cab SR5, 2wd 3.91 gear ratio.
    I have a line on a 2004 ABS diff and 3rd member. Other than my vehicle not having ABS, is this compatible? I have seen that it is, but I want to know what this community has to say.
    Thanks for your time in responding.
    Shawn
  2. Aug 28, 2018 at 4:04 PM
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    Yeah it should work. Since it’s 2wd gear ratio is not critical on the new axle but keep in mind 4wd rear axles use slightly different yokes than 2wd axles. Worst case you’ll have to swap the yoke with one off your old axle.
