Rear diff locker: Do they make an E Locker for Tundras?
Discussion in '2nd Gen Tundras (2007-2013)' started by JTP, Jun 3, 2017.
  1. Jun 3, 2017 at 4:34 PM
    JTP
    JTP [OP] The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    Looking at the G2's and the Nitro's for the 4:88 re-gear. Wanting to go ahead and do a rear Locker. LSD will be a "wear" item and only hold up for 20 to 30K miles so they are out.
    Not too fond of the ARB or any other AIR type lockers due to air system freeze and other air system failures. Wondering if anyone has found an E (electric) Locker out there?
    nuclearlemon likes this.
  2. Jun 3, 2017 at 6:26 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Yeah, the 10.5" rear axle only has the ARB and an Auburn LSD as aftermarket options. I've wheeled in plenty of cold areas with my compressor mounted in the frame rail (with the suction up in the engine bay near the other breather tubes) and haven't had any problems. As long as a good mechanic installs it there shouldn't be any leaks or problems. It's a much more robust differential than the Toyota designed differential case.
  3. Jun 3, 2017 at 6:33 PM
    JTP
    The Big Black Moose
    Sweet! Thanks for the info. I went ahead and pulled the trigger on the Nitro's and got the Auburn Pro LSD. Im not going to be hard core off road and figured for snowy roads up through Canada and in Alaska a full locking diff was not going to work on regular highway and daily driving.
    Hope that the clutch plates don't wear out too soon on that Auburn. Found some gouge where they are going more than than the 20 to 30K so I will be one of the Ginny Pigs. Will see how good the Trac Control works combined with this.
  4. Jun 3, 2017 at 6:34 PM
    JTP
    The Big Black Moose
    Whats the deal on the Auburns? Are they lasting if not abused?
    Found a TON of Youtube videos with SC Tundras running the crap out of them. Wondering if I drive "normal" if they will last.
    https://youtu.be/ZMSwLRg-hhY
  5. Jun 3, 2017 at 6:55 PM
    computeruser6
    Dirk
    Escondido
    JTP[OP] likes this.
  6. Jun 3, 2017 at 7:01 PM
    JTP
    The Big Black Moose
    Good observation, no complainers is a good thing.
    Like I said there are a lot of SC guys running them and so is Nitro in their promotional Super Charged Tundra. Found a bunch more serious mud guys running the Auburn LSD too. Might have stumbled onto something here that just might be a good way to go for us less hard core guys where we get the best of both worlds.
    Will call www.justdifferentials.com where I ordered my stuff and pick their brains on how well these hold up on Monday and ask if those clutch pads are replaceable if they were out.
    zcarpenter92 likes this.
  7. Jun 3, 2017 at 7:10 PM
    My last limited slip differential was in a Dana 80, and it stopped working well at 145,000 miles, and at 170K miles it was a one wheel wonder. Not sure where you are getting the info on LSD wearing out at 20-30K miles.
    The Auburn LSD is not a rebuild unit, but through the Dex-X exchange program is the same cost as a rebuild kit from other kits. They have the best warranty in the business, that is for sure. 4 years is pretty good.
    Remember NOT to use synthetic fluids and LS additive.
  8. Jun 3, 2017 at 7:16 PM
    JTP
    The Big Black Moose
    Thank for the input Co TJ :thumbsup:
    The low milage info was from $$$$ 4 WHEEL PARTS $$$$ :bananadead:
    UP SELLING ARB LOCKERS and pushing the G2's which are NOT a complete kit. Additionally, The Nitro's use OEM Toyota parts, the G2's do not.
    Nitro's were even a few bucks cheaper with no sales tax and free shipping.
    Went to 2 of their shops today (4WP) here in DFW area and got the same response, LSD SUCKS and I needed their G2's and the ARB locker.
    Pays to shop for sure.
    Will look for a local mom and pop shop for the install vs them. They will probably bitch anyway about installing the gears and LSD that they don't offer or sold me anyway.
  9. Jun 3, 2017 at 7:20 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I have my 4.88s and auburn rear LSD being installed in less than two weeks. When I spoke with Auburn gear customer service department they suggested the following specs for the rear diff.
    Auburn rear differential
    High performance differential limited slip
    10 1/2 12bolt
    Part number:
    5420134
    36 spline axial
    Non synthetic oil
    80-90 Weight oil with additive
    Jsena, aperezsh and JTP[OP] like this.
  10. Jun 3, 2017 at 7:22 PM
    JTP
    The Big Black Moose
    What gears did to go with? I got the exact same Auburn unit.
  11. Jun 3, 2017 at 7:27 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Auburn technical support said that only if you intend to off-road do you need a full locker. Plus they also said with a front independent suspension they don't suggest running a front locker. Unless you intend to drive straight with a front locker ingaged. The LSD differential on the other hand they said would help power transfer to both rear tires equally versus power to just one rear tire. That's why I chose to go with the Auburn LSD.
    JTP[QUOTED][OP] likes this.
  12. Jun 3, 2017 at 7:28 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Auburn G2s
  13. Jun 3, 2017 at 7:30 PM
    JTP
    The Big Black Moose
    4 wheel drive will only get you stuck another couple of hundred feet further from the road. :0
  14. Jun 3, 2017 at 7:31 PM
    JTP
    The Big Black Moose
    Where are you doing the install? $ ?
  15. Jun 3, 2017 at 7:31 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Here is all the parts list from 4wheel parts for my gear swap and LSD. IMG_7922.jpg
    JTP[OP] likes this.
  16. Jun 3, 2017 at 7:33 PM
    OK, now I know why...4WP...they wouldn't even have the opportunity to check the air pressure in my tires.
  17. Jun 3, 2017 at 7:34 PM
    JTP
    The Big Black Moose
    I got the same list except for the LSD. Labor for gears only was $935.00
    Loos like there is nothing to installing the LSD while they have it all part. Im curious what they are charging you for installing it all.
  18. Jun 3, 2017 at 7:44 PM
    1UPPER
    TEXAS
    Flux capacitor!
    4wheel parts is a huge national chain so each store will vary. The 4 wheel parts store in San Antonio does the majority of Toyota Tundra lifts and modifications in S.A. Plus they have done over four different trucks and have stood behind their work. That's my own personal experience. Plus most of the guys at my local 4wheel parts have been there for over 10 years and are very knowledgeable.
    ColoradoTJ[QUOTED] and JTP[OP] like this.
  19. Jun 3, 2017 at 7:50 PM
    JTP
    The Big Black Moose
    Right guys that really know what the f they are doing is everything.
  20. Jun 3, 2017 at 7:54 PM
    Totally agree. The rather large stores in Denver and Colorado Springs doesn't impress me, but I don't use the products they offer either. Glad that SA is better.
  21. Jun 3, 2017 at 8:04 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I'm at $940 for labor on gears and LSD but my buddy is the manager. The cost to do the LSD shouldn't be that much more since they already have the rear diff disassembled for the gear swap. If you do the LSD at a later date it should be $400 or more for labor.
  22. Jun 3, 2017 at 8:55 PM
    JTP
    The Big Black Moose
    Right at the same dollar amount to do it all at the same time. Im wondering if they will have an issue with installing the Nitro gears vs the G2's. The kit is 100% complete and has all OEM Toyota parts. Will wait to get my parts here and then give them a call to take their temperature.
  23. Jun 3, 2017 at 9:54 PM
    zidaro
    zidaro New Member
    E. Sierras, CA
    '10 Crewmax
    yes
    Been running the Auburn for 2 years now. with 4.88s. Purchased and Built by Just Differentials, i installed the diff. Simple. Have an ARB up front as well.
    You'll love the improvements felt from the Auburn. Can break both tires and have a nice power slide with the nannies turned off, also see a much lower incidence of the nannies kicking in on slippery roads withe the traction improvements. Will certainly help you up n over obstacles that you will spin a wheel on now.
    Enjoy
  24. Jun 3, 2017 at 9:56 PM
    JTP
    The Big Black Moose
    Excellent. You must be bashing some serious off road needing the front ARB.
  25. Jun 4, 2017 at 3:18 AM
    Berettafan
    Berettafan New Member
    2017 CM
    I thought lsd was a bad thing on snowy or slippery roads. The selling point of on demand lockers like the arb is you're only locked when you want to be.
    JTP[OP] and ColoradoTJ like this.
  26. Jun 4, 2017 at 4:35 AM
    That depends on your throttle use. When the LSD detects wheel slip and engages, under moderate throttle the rear end of the truck shouldn't be walking out on you.
    JTP[OP] likes this.
  27. Jun 4, 2017 at 7:25 AM
    JTP
    The Big Black Moose
    "under moderate throttle use "
    thats the ticket
    :thumbsup:
  28. Jun 4, 2017 at 8:06 AM
    JTP
    The Big Black Moose
    This is an example of "moderate use of throttle" in REVERSE. Substitute snow for the sand. The LSD along with the gears is going to be the shit! :curls:
    Im feeling one tinny little burn out video of my own coming on just for fun when I get these installed.
    https://youtu.be/JJlW3oCJH6c
  29. Jun 4, 2017 at 8:25 AM
    1UPPER
    TEXAS
    Flux capacitor!
    Just make sure you take it easy so your gears can break in and mesh for the first 500-1000 miles.
    RitcheyRch and JTP[QUOTED][OP] like this.
  30. Jun 4, 2017 at 9:53 AM
    zidaro
    zidaro New Member
    E. Sierras, CA
    '10 Crewmax
    yes
    No bashing, atleast not what i consider bashing :0
    But... I live in the Eastern Sierras and we see a ridiculous amount of snow every year.
    4runner under that lump in my driveway
    And i do spend a lot of time in the Cali deserts and Baja cruising around. Plenty of rocky washouts and deep sand that would be a serious issue if you were to get stuck and stranded. The ARB, like my winch, are for those times. When you need to get thru. A front locker is not something you run while "wheeling", it is used to get you thru a section of tough.
    As far as a LSD in slippery. It actually is the one type of traction device that makes a huge difference (improvement). A locker wants to push or pull one tire thru the slide, causing it to break free or slip. The LSD, on the other hand, detects slippage or spin in one wheel, and then transfers power to the wheel with traction.
