Rear Dashcam Camera Mount Tundra Platinum
Discussion in '2.5 Gen Tundras (2014-2021)' started by lamikela1, Dec 21, 2018.
  1. Dec 21, 2018 at 8:59 AM
    lamikela1
    lamikela1 [OP] New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    I didn't see anything on this in my search but on a Tundra Platinum with the one piece power rear window has anyone found a good way to mount a rear facing dashcam? I have a BlackVue 2 channel cam on order and need to figure out how to mount this.
    For now I am thinking that i will need to find a way to mount it to the rear of the center headrest.
  2. Dec 21, 2018 at 11:29 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
  3. Dec 21, 2018 at 12:37 PM
    kkim124
    kkim124 New Member
    Torrance, CA
    2016 Tundra Platunum 4x4
    I folded up a thin piece of metal to slip over the rear of the headliner and placed the rear camera to that. That way there is no permanent holes or makes if I take it off.
    JoshuaA likes this.
  4. Dec 21, 2018 at 12:41 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    I’d suggest dropping the headliner a little and mounting it with a short self-tapping screw into the metal of the rear of the 3rd brake light housing. It will give you a solid mount, come around the headliner and look nice, and won’t interfere with the window.
  5. Dec 21, 2018 at 3:16 PM
    DesertLead
    DesertLead New Member
    Ron
    2018 Tundra Platinum CM
    Kings & Deavers
    I just did this - I used some Kydex I ordered from Amazon. Heated it up and bent it to the approximate angle. You can adjust the rear Blackvue once it's mounted. Awesome camera - I have the 900 series. Great video!!
    itstorbs likes this.
  6. Dec 21, 2018 at 3:18 PM
    DesertLead
    Ron
    Kings & Deavers
  7. Dec 21, 2018 at 3:24 PM
    DesertLead
    Ron
    Kings & Deavers
    I slid it up under the headliner so it has a better angle and isn't interfering with seeing. I'll try to get a pic or two if you need it.
  8. Dec 21, 2018 at 3:42 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    Did you tuck the cables in the headliner? Can you take pictures of your setup?
  9. Dec 22, 2018 at 5:01 AM
    DesertLead
    Ron
    Kings & Deavers
    Yes - it was very easy to run the wires using a plastic pry tool and going slowly. The biggest issue is there's a ton of extra wire left for the rear camera in the Tundra. I tucked it up into the headliner trying not to push it too far forward. I was thinking it could possibly interfere or get tangled in the sunroof mechanism. I'm not sure what's under there...
    I ran the rear camera wire off the passenger side, and the front camera off the driver side.
    I am also using the battery pack which I tucked under the driver's seat.
    The battery is tapped into the fuse box under the front hood as there wasn't a 15amp fuse under the dash in my 2018 Platinum that didn't draw power with the ignition off. You only want power to recharge the battery when the ignition is turned on - otherwise, you'll drain your truck's battery.
    I will try to post something up. I was thinking about a short video. I'm buried most of the weekend with work but, worst case, I'll knock it out Monday.
  10. Dec 22, 2018 at 7:16 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    Thanks Ron!
  11. Dec 22, 2018 at 4:35 PM
    tundraforme
    tundraforme New Member
    Em
    Vancouver, BC
    2018 Tundra TRD Off Road Quicksand
  12. Dec 22, 2018 at 4:49 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I wedged a $40 Yi in the corner:
    22CE5181-A649-4966-B13D-7CB8F666E3C3.jpg CF268A74-36B9-4745-92C7-16CE050DF4E7.jpg E4F29497-59FA-43AD-A94A-24214ECC7D6D.jpg 61715071-FB39-4156-A2B9-1FABD1C2337D.jpg
  13. Dec 23, 2018 at 6:05 AM
    jagged155
    jagged155 New Member
    2018 Platinum Pro
    I used a magnet. Very easy
  14. Dec 24, 2018 at 9:05 AM
    lamikela1
    Michael
    All good ideas!!! The cam should be here this week so once I take a look at the mounting bracket and the headliner/rear window I'll decide on which option to use. I am leaning towards the Kydex or magnet (this one is interesting). Once i get it mounted I will send pictures.
    I have a DRS650 2CH on my Lexus and it was really easy to install that one. The most time I spent was to find a good power source. I ran the wires on the right side of the car but on the Tundra I will be running them on the left since all the work to install the Fortin alarm and RS will be on that side. I will be doing both the cam and alarm/RS at the same time to avoid taking everything apart twice.
    porkitt likes this.
  15. Dec 24, 2018 at 9:11 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    Pictures?
  16. Dec 24, 2018 at 9:13 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    :popcorn::popcorn::popcorn:
  17. Dec 24, 2018 at 9:18 AM
    jagged155
    2018 Platinum Pro
    Will take some soon
  18. Dec 24, 2018 at 9:27 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    If the headliner is easy enough to pry, then combining a strong magnet glued to kydex, maybe it will help with stability.
  19. Jan 16, 2019 at 9:07 AM
    lamikela1
    Michael
    I now have my BlackVue dashcam installed and was lucky enough to find a weird looking bracket for the rear in some old stuff that I had. It's kind of "W" shaped and hooked into the rear window gasket at just the right angle to not hit the glass or pinch the seal. It's made of clear plastic and is about 1/8 inch thick. Made the rear cam mount really easy. Thanks again for all the ideas.
    Rear cam.
    OppLPipItbMwaKJvBKxNzx3OlbzWqR0--nXSn1c3_cdba094fddea6e490d260301c2828a4c28a8abd3.jpg
    wiENzY4B-FBilV1qOH173MIik-vDYyPbqIHotU_a_becbdc6bacae39db74cd45f1eb65bda04e52d3ff.jpg
    Front cam.
    I736RkQTCHAJld8VmAHCge2gdW-L9GXM-U-BNT4F_78bda52b8620edad97d458c2daeb54d088d4b7cc.jpg
  20. Jan 16, 2019 at 9:16 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Looks like a bunch of great installs. Looking at it gave me an idea though- if you got a used/wrecking yard 3rd brake light assembly, wouldn’t it be possible to drill a hole in the reflector, mount a small camera inside the brake light housing, and run your wire forward through the cab, above the headliner?
    DjSamthrax likes this.
  21. Jan 17, 2019 at 7:40 AM
    lamikela1
    Michael
    I would think that would work if the camera is small enough and did not interfere with the light itself. Unfortunately the BlackVue one is probably too big for that. Maybe others have a smaller camera.
  22. Jan 17, 2019 at 8:10 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    Did you drop the whole headliner off?
  23. Jan 17, 2019 at 2:06 PM
    lamikela1
    Michael
    I had to do nothing with the headliner. That was probably the easiest part of the entire install. All I did was to tuck the wire under the door rubber molding at the top of each door. Once you get it under the molding you can push it under the headliner. At the B pillar once again I tucked it in place. The A pillar molding has to be removed to run the power down to the dash. only one screw there and just pull it off. At the front and back glass again you can just tuck it in. That was it!
  24. Mar 7, 2019 at 7:23 PM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    Do you have any pictures of this?
  25. Dec 3, 2020 at 5:34 PM
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Minnesota
    2020 TRD Pro Tundra, 8371 Club
    Coachbuilder Pro Kit, 35x12.5 BFG KM3s, Baja S8 hood mounted, Rago Lo-Pro Brackets sitting empty at the moment, Rago Dash Divot Plate, AJT Stuff, LED Lighting throughout, TRD Intake, Bedliner, Tint, Full front PPF, SPS Graphene Coating, and dropped the B out of JBL ;-)
    Subscribed....
  26. Dec 3, 2020 at 5:55 PM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    EatSleepTacos and TaquitoBandito like this.
  27. Dec 3, 2020 at 10:10 PM
    PaulROahu
    PaulROahu New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    Mounted my rear in the headliner, fit is snug and dead center
  28. Dec 5, 2020 at 10:22 PM
    DjSamthrax
    Minnesota
    Everyone happy with their angle and view top center?
  29. Dec 7, 2020 at 1:39 AM
    LKROOZR
    LKROOZR New Member
    Christian
    2017 Black Tundra Crewmax
    8" readylift on 37s
  30. Dec 10, 2020 at 4:57 PM
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    just curious, but how useful is the video from the rear dash cam at night? I figure that either you're going to be getting a reflection off the rear window, or you'll just have the headlights from the car behind you wash out the whole picture
