Rear cigarette lighter/power outlet not working
Discussion in '2nd Gen Tundras (2007-2013)' started by Quik615, Jul 12, 2018.
  1. Jul 12, 2018 at 6:10 PM
    Quik615
    Quik615 [OP] New Member
    I have a 2013 Toyota Tundra double cab and the rear cigarette lighter/power outlet on the lower back of the center console is not working (no power). When I purchased it I had the dealership put in leather seats and I am thinking they forgot to plug something back in. I have done some googling and came up empty handed. I was hoping you guys could help or point me in the right direction. Any help would be greatly appreciated :)
  2. Jul 12, 2018 at 6:43 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    What about the other 2 power outlets - the one inside the console box, and the right side one in the dash? The three share a common fuse, in the fuse panel under the dash. If they are powering up normally with the ignition turned on, then your theory is an excellent one.
  3. Jul 12, 2018 at 7:04 PM
    Quik615
    Ah nice! Yeah those are working. So is plugging it in an easy job? How do I gain access to that?
  4. Sep 19, 2020 at 11:52 PM
    TBoetcher
    TBoetcher New Member
    2012 Tundra PU 4.6L
    let me ask I have a 2012 tundra pu ,the power ports and console and rear seat lighters arent getting power. The fuse is good anyone have any ideas.
  5. Sep 20, 2020 at 9:34 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    There is 2 separate fuses for these, but odds are you may need to take your console apart. If you open the lid, the forward part of that console can be easily lift up with both hands, then remove the carpet at the bottom of the console, there should be 4 bolts on each corner and the console can pretty much lift up. There you can double check if the harness was damaged in any way, or not plugged in.
