Rear camera
Discussion in '2nd Gen Tundras (2007-2013)' started by Overwatch91, Apr 3, 2019.
  1. Apr 3, 2019 at 8:27 AM
    Overwatch91
    Overwatch91 [OP] Initial Success or Total Failure!!
    Michael
    East Texas
    2013 White Tundra TSS
    Since I bought my truck, my rear camera is intermittent. Sometimes it works and sometimes it doesn't. Loose wire or need a new camera?
  2. Apr 3, 2019 at 8:48 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    New? Used? Factory? Aftermarket? When I ran into that problem on my aftermarket camera and head unit I went behind the dash while updating to a newer head unit and found out the installer did the 'strip, twist and tape' method to tie the wiring into what was coming out of the head unit, and a loose connection was moving around behind the dash causing it to go in and out. I threw in a proper T-splice wire connector and haven't had any problems since. Wiring connections are the first place I would start if it still works some of the time.
    rebmo likes this.
  3. Apr 3, 2019 at 2:02 PM
    Overwatch91
    Michael
    East Texas
    It's OEM. When I bought the truck used it worked. Now it's intermittent.
