Rear Camera Fail?
Discussion in '2nd Gen Tundras (2007-2013)' started by tnbndr, Nov 7, 2019.
  1. Nov 7, 2019 at 6:55 AM
    tnbndr
    tnbndr [OP] New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    Just started this week. When I put vehicle in reverse, the screen in the rear view mirror is solid blue and text at bottom says "check your surrounding before moving".
    When I start to move the screen goes away.
    Is the camera failing? I checked the wiring, it is all connected.
  2. Nov 7, 2019 at 8:39 AM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Same issue here. Except this week it’s working fine.
    There are two fuses in the engine fuse box (24&25?) and two in the drivers footwell that allegedly go to the backup cam and other things. Can’t remember exactly which ones, but it’s in your manual. Mine were fine, but worth looking into.
  3. Nov 7, 2019 at 8:47 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Mine did that. Replaced the camera and it worked again. Might be that the camera is bad if all the wiring and fuses check out.
