Rear Caliper Slide Pin boots
Discussion in '2.5 Gen Tundras (2014-2021)' started by agrestic1, May 7, 2022.
  1. May 7, 2022 at 6:58 AM
    agrestic1
    agrestic1 [OP] New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Did a search and couldn't find much info, so looking to replace a torn slider pin upper boot on right rear caliper, 2016..I find a lot of the same kits, but question is does one kit do one caliper, would like to change all boots since I'm doing new rear pads and rotors, Thanks
  2. May 22, 2022 at 4:46 PM
    agrestic1
    2016 CrewMax
    So in case anyone wants to know, the kit does both rear calipers, each caliper has one full length rubber slide pin boot and one just the short pin boot. Pull out the full boot, clean hole with pipe cleaning brush of sorts, insert rubber boot carefully with blunt tool like long bolt..clean other pin hole with brush. Use plenty of slider lube of your choice..
    Installed rear DBA slotted rotors and Green EBC pads..
    WILLINH and landphil like this.
  3. Sep 17, 2023 at 9:51 PM
    bmtrujillo98
    bmtrujillo98 New Member
    What are the little rubber circles for?
  4. Sep 17, 2023 at 10:07 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I think that’s the bleeder cap
  5. Sep 17, 2023 at 11:07 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Thanks for the info!
