Rear Bumper Mount Pull Out?
Discussion in '1st Gen Tundras (2000-2006)' started by DesertRoads, Nov 30, 2022.
  1. Nov 30, 2022 at 9:36 AM
    DesertRoads
    DesertRoads [OP] Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    When I purchased my '05 Double cab, it came with being offset rear ended (hit on just the right side). What is the best way to pull out the right side bumper mount? I imagine the bumper mounts are shock absorbing, so when rear ended they are like springs that give way when rear ended so frame damage doesn't occur. Am I right on that assumption? Or....? I know body shops pull out pushed in mounts all the time, so I'm curious if it's something I can do, or will I need to take it to a shop?
  2. Nov 30, 2022 at 9:48 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I would just take it all off and straighten the bracket off the truck
    Jack McCarthy likes this.
  3. Nov 30, 2022 at 10:14 AM
    DesertRoads
    Utah's West Desert
    The bumper is crushed. I'm asking if it's a mount that is pushed in. I guess I'll just have to take it to a body shop to have it pulled out.
  4. Nov 30, 2022 at 10:29 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Yeah, there are braces that attach the bumper to the frame. If hit hard enough the frame can be damaged but for the most part they can be replaced if needed.
  5. Nov 30, 2022 at 10:37 AM
    alb1k
    Left Coast
    It's good
    Or take some pictures so we know what you’re talking about
  6. Nov 30, 2022 at 12:41 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    If it's not one of these parts you're talking about, then it's the frame...
  7. Nov 30, 2022 at 12:45 PM
    Jack McCarthy
    Bill
    North of Boston
    I believe he’s referring to #2 & #3 which can either be bent back in shape or replaced.
  8. Nov 30, 2022 at 12:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    There are no springs, or shock absorbers back there that can spontaneously esplodey and hurt you. Just two bolts on each side of the frame for the bumper mount, and then the bumper is mechanically free from the frame.
    There is wiring for your license plate lights. Remove those first before taking the bumper off.
  9. Nov 30, 2022 at 1:47 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    This diagram doesn't show it, but the bumper also has braces that run vertically. I backed into our RAV4 a few years ago and noticed that brace when inspecting my own bumper.
  10. Dec 1, 2022 at 10:15 AM
    DesertRoads
    Utah's West Desert
    I'm guessing it's #2 that is bent. I'll have to look into that. Thank you!
