Rear bumper light bar kit????
Discussion in '2.5 Gen Tundras (2014-2021)' started by Machodiver, Aug 16, 2015.
  1. Aug 16, 2015 at 8:51 PM
    Machodiver
    Machodiver [OP] New Member
    James
    2015 Black SR5 Tundra CrewMax
    Was wondering if anyone knows of a light bar kit, that can be spliced in to the back up lights??? Need more light when backing up at night.
  2. Aug 16, 2015 at 9:32 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    The existing backup wires probably can't handle the current directly. But you should be able to splice in a relay and then run a bigger wire back from the battery.
  3. Aug 16, 2015 at 9:38 PM
    Machodiver
    James
    Do you know if they make a kit like that though???
  4. Aug 16, 2015 at 10:57 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Not that I know of, at least not specifically. However, a light is a light and does not know where on the truck it is being mounted. Just buy a light kit that includes a relay harness, and mount it on the back. Instead of tapping into the headlight circuit, as you normally would, you'd instead be tapping into the backup light circuit. Also, one of the relay harness wires goes to the battery (its typically a red one with an inline fuse). You'd need to extend that wire to reach the back of the truck.
    Machodiver[OP] likes this.
  5. Aug 16, 2015 at 11:01 PM
    Machodiver
    James
    I'm going to look into it. Thanks for all of the great information.
  6. Aug 17, 2015 at 4:48 AM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    image.jpg Wired directly to my reverse lights so they come on automatically in reverse.
    SullyMoto19 and Black Wolf like this.
  7. Aug 17, 2015 at 8:27 AM
    This is what I was going to recommend. Toytec did the same on their truck.
  8. Aug 17, 2015 at 8:43 AM
    TNTundra08
    Blake
    2008 DC 4x4
    I really like them. Rigid makes a little insert to put some angle on them, that would be even better.
    And I just got cheap "knock off" ones from Amazon. I have less than $50 in those and haven't had any issues so far (2-3 months).
  9. Aug 17, 2015 at 4:19 PM
    Platinum14MBSC
    Platinum14MBSC Upgrade 2023 from 2014 SC
    bradley
    myrtle beach
    2023 TUNDRA
    Just purchase 10/10/2024
    Just installed these, I plan on covering them with a film which will black them out but not cut back on light output.
    T-Rex266 likes this.
  10. Aug 17, 2015 at 8:22 PM
    Machodiver
    James
    Are those connected to your reverse lights???
  11. Aug 17, 2015 at 8:30 PM
    Platinum14MBSC
    bradley
    myrtle beach
    2023 TUNDRA
    Yeah, I didn't run a relay or fuses. They are small enough I don't believe I will have any issues. It ever blows a fuse I will run a relay.
  12. Aug 17, 2015 at 8:52 PM
    Machodiver
    James
    Awesome. Where did you get them?
  13. Aug 17, 2015 at 8:54 PM
    Black Wolf likes this.
  14. Aug 17, 2015 at 8:56 PM
    Machodiver
    James
  15. Aug 17, 2015 at 9:00 PM
    Platinum14MBSC
    bradley
    myrtle beach
    2023 TUNDRA
    I will let you know next time I'm in the woods! Lol I will do a before and after pic but they couldn't hurt.
    rons23 likes this.
  16. Aug 17, 2015 at 9:07 PM
    Platinum14MBSC
    bradley
    myrtle beach
    2023 TUNDRA
  17. Aug 17, 2015 at 9:12 PM
    T-Rex266[QUOTED] likes this.
  18. Aug 17, 2015 at 9:15 PM
    Platinum14MBSC
    bradley
    myrtle beach
    2023 TUNDRA
    Shoot, can't do the before without cutting wires! I can tell the difference
  19. Aug 17, 2015 at 9:18 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Put tape over them for the "before". Definately look bright.
  20. Aug 17, 2015 at 9:23 PM
    Platinum14MBSC
    bradley
    myrtle beach
    2023 TUNDRA
    Yeah I'm tired!
  21. Aug 17, 2015 at 9:29 PM
    Machodiver
    James
    Does it come with the mounts???
  22. Aug 17, 2015 at 9:30 PM
    Probably not. But not a big deal. Does come with 2 screws with each light. Go to ACE or Home Depot and fab your own mounts. Piece of cake.
  23. Aug 17, 2015 at 9:32 PM
    Machodiver
    James
    Maybe not for you guys. I'm good at install but not fabrication. Lol
  24. Aug 17, 2015 at 9:35 PM
    Machodiver
    James
    Any idea for mounting?
  25. Aug 17, 2015 at 9:36 PM
    Really, it's not a big deal. Not really fab. Just look around for something that will work for brackets or mounts. Use your imagination. I do it all the time. Sometimes I make a couple of trips until I'm satisfied.
  26. Aug 17, 2015 at 9:36 PM
    Platinum14MBSC
    bradley
    myrtle beach
    2023 TUNDRA
    They come with mounts, it's tricky getting them to attach to the tow package.
  27. Aug 17, 2015 at 9:38 PM
    Maybe when it's daylight and you have time you can take a good pic of the mounting set up and post. Thinking more folks here may want to get a pair of these.
  28. Aug 17, 2015 at 9:41 PM
    Machodiver
    James
    I am for sure buying these in the morning. :devil:
  29. Aug 17, 2015 at 9:43 PM
    Definitely this.
  30. Aug 17, 2015 at 9:45 PM
    :cheers:
