Rear Brakes
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rustyscrew, Jan 23, 2020.
  1. Jan 23, 2020 at 4:36 PM
    Rustyscrew
    Rustyscrew [OP] New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I’m going to be replacing my rear brakes tomorrow. Will be my first time doing it on my truck. Any tips or suggestions?
  2. Jan 23, 2020 at 5:01 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    If you've never done it before watch some youtube videos. If you have, then it's all the same stuff as on any other car or truck
  3. Jan 23, 2020 at 5:07 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    They're pretty easy to do. Use a wire brush or light file to clean up where the slide clips go. You shouldn't have to force the new clips into place. Use some brake cleaner to clean up the caliper, especially around the pistons and go with a thin, even film of grease on the slides and backs of the pads (grease should come with the pads). If you remove or are putting on new rotors the emergency brake shoes may fight you when reinstalling the rotors. They can be moved around a little and the rotors should slide right on.
    Mcoop likes this.
  4. Jan 23, 2020 at 6:25 PM
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    I am going to replace the rotors along with the pads.
  5. Jan 23, 2020 at 6:36 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    A 2x4 and heavy maul will help tremendously in knocking the rotor loose.
