Rear brakes dragging?
Discussion in '2.5 Gen Tundras (2014-2021)' started by HARPER306, May 17, 2022.
  1. May 17, 2022 at 2:39 PM
    HARPER306
    HARPER306 [OP] New Member
    SK, Canada
    2020 Voodoo TRD Sport CM
    With the nicer weather starting to make an appearance I've been driving more with the rear window down and I'm hearing what sounds like brakes dragging just a bit. Like a metallic constant rubbing. I pulled off both rear wheels, put the truck in neutral and turned the rotors and there is some resistance but not a lot. Rear rotors are also noticeably hotter to the touch than fronts after a drive. Doesn't seem like a dust shield issue, but I really don't know if the wheels should fully free wheel or if there should be some rub/resistance. It's possible this started when I rotated my wheels as I used the e brake while it was in the air, but I can't be certain. Is there anything I can check with the e brake to see if it's hanging up a bit? TIA
  2. May 17, 2022 at 3:11 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Pull the caliper pins out and grease them
  3. May 18, 2022 at 6:41 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    And, check for rust on the rotors, sometimes after sitting you may get some rust, noise would go away after using the brakes a few times
  4. May 18, 2022 at 9:04 AM
    timsp8
    NY
    MEWaters and HARPER306[OP] like this.
  5. Jun 7, 2022 at 2:18 PM
    JonnyT
    JonnyT New Member
    Jonny
    2015 Tundra SR5 Dc
    OP, did you find the cause?
  6. Mar 25, 2023 at 4:12 AM
    Wood21
    Wood21 New Member
    I just started experiencing this exact issue. Gonna dig into it in the next couple days. Love to hear the outcome of this case.
