Rear Brakes. Dealer or private shop
Discussion in 'General Tundra Discussion' started by rsttoole, Jun 2, 2021.
  1. Jun 2, 2021 at 5:59 PM
    rsttoole
    rsttoole [OP] New Member
    Randy
    Boise
    2008 Tundra Limited
    Need rear brakes on my 2008 tundra DC. Undecided about cost at dealer and quality of work at independent shops. Looking for recommendations,
    Thanks in advance.
    TNCountrygal likes this.
  2. Jun 2, 2021 at 6:00 PM
    rsttoole
    Randy
    Boise
    2008 Tundra Limited
    By the way. New to me with 80k on it
  3. Jun 2, 2021 at 7:31 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    A private shop should be capable. If just pads, it's not a real hard DIY. Youtube videos and/or maybe a handy friend can save some $$.
    omgboost, jeremyd and equin like this.
  4. Jun 2, 2021 at 7:37 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    I just did mine Saturday and only took 45 minutes.
    All you need is a 17mm wrench, flat head screw driver, and a C clamp.
    TNCountrygal, jeremyd and Hightide like this.
  5. Jun 2, 2021 at 7:39 PM
    rsttoole
    Randy
    Boise
    2008 Tundra Limited
    I know it's easy. We sold our house and all of my stuff is in storage for a few months.
    Dealer or independent shop? If independent, quality of parts?
  6. Jun 2, 2021 at 7:41 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    This.
  7. Jun 2, 2021 at 7:53 PM
    ZiaTundra
    ZiaTundra New Member
    I’d think a independent shop with good reviews could handle it. I’m thinking about having an independent shop do my water pump.
    WILLINH likes this.
  8. Jun 2, 2021 at 8:00 PM
    Trooper2
    JR
    You tell the shop what mfg parts you want or supply your own parts. Toyota pads are really good for normal duty.
  9. Jun 2, 2021 at 10:34 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Buy OEM parts online from the dealership, pick them up in person, deliver to the indy shop for install.
    Or check to see if the dealership is running any specials on brake jobs. I see ads every now and then from my service dept for $$ or % off of basic jobs.
  10. Jun 3, 2021 at 1:00 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    So you don't need to resurface the rotors?
  11. Jun 3, 2021 at 5:03 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    As others said, I’d find a reputable independent shop and supply my own parts if they don’t use what you want. Dealers charge exorbitant amounts of money for labor.
  12. Jun 3, 2021 at 5:47 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have done a lot of brakes and never have. I will run some 800 grit to remove glazing but not really necessary. The way I look at it if the rotors need to be turned there is a good chance they need to be replaced.
    equin, omgboost, TNCountrygal and 4 others like this.
  13. Jun 3, 2021 at 5:48 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Good point. I was thinking the same thing. You would needed a micrometer to measure the disc rotor thickness. These days they seem to replace rotors. Not many cut rotors anymore.
    1lowlife[QUOTED] likes this.
  14. Jun 11, 2021 at 2:35 PM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    DIY
  15. Jun 11, 2021 at 2:38 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Independent shop.
  16. Jun 11, 2021 at 2:46 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    DIY. Not difficult.
    equin and TNCountrygal like this.
  17. Jun 11, 2021 at 2:52 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    The rears are a piece of cake. Get a complete kit, back off the rotors using the threaded holes, open your master cylinder, and use a clamp on the pistons to push them back in. The fronts are a little bit more involved but the rears are nothing to be afraid of.
  18. Jun 11, 2021 at 3:53 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    It’s a simple job. Quality of work? I’m not sure how someone can screw up rear brake shoes. Go with a reputable shop that will let you use OEM shoes to save a few bucks. Time is money, I get it. Not something you want to waste your afternoon doing if you have more important things to do.
  19. Jun 11, 2021 at 4:04 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    If the rotors need turning I would just replace them
  20. Jun 11, 2021 at 4:26 PM
    2mchfun
    Buy a few tools, you can save $$
  21. Jun 11, 2021 at 7:03 PM
    TNCountrygal
    TNCountrygal New Member
    Lenoir City, TN
    2014 MGM 4X4 1794 Tundra
    This! :amen: This is the reason not to go to the stealership. They will insist on turning the rotors. Then they get thinner ever time and are then more prone to warping. Unless you ran the pads insanely low or got a rock stuck in there, they shouldn't need the resurface. I'd suggest OEM pads. You can borrow the tools from Auto Zone.
    2mchfun likes this.
  22. Jun 11, 2021 at 7:08 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I got quoted 399.99 per axle at the stealership... I had to have them repeat it to make sure I heard correctly.... took it a reputable shop down the road for 300 for all 4 corners... mind you guys it was fwd and drums in the rear..
  23. Jun 12, 2021 at 4:58 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    That is why we call them stealerships. They love to see women and the uniformed and rip them off
    blackdemon_tt[QUOTED] likes this.
  24. Jun 13, 2021 at 4:58 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Since you are busy with the sale of your house the question is..... Do you have a good mechanic?
    A mechanic that does good work, uses the parts you request and charges a fair price is VERY tough to find.
    I can't tell you how many shops I have been through. Some are just butchers. On my Chevy one guy got the wrong tie-rod end and just shoved it up into the sleeve.
    Another was excellent, but busy and got to be abusive and expensive. I'm paying you. Don't give me a hard time please.
    I finally found a new shop owner. Purchased the place from a retiring mechanic. The guy is great.
  25. Jun 13, 2021 at 5:36 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I did it myself using OEM rotors and TRD pads front and back. Parts cost me $550 and a few hours of my time watching YouTube and doing it. Dealerships will charge you MSRP for parts and quote you on book time even if it doesn't take them that long. Independent shops may use aftermarket parts to quote a lower price but some will let you bring your own parts and they will charge you the labor but no warranty on the work.
  26. Jun 15, 2021 at 8:52 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    I do not turn rotors anymore. I have read that taking metal off affects heat dissipation capabilities and just makes them more prone to deform in hard use later. Regardless of the extent to which that's true, I have found total prices to replace to be comparable to the labor of taking them off and going through the labor of grinding them down and getting them true so I don't find much or any savings in turning vs. replacing. I generally haven't needed brake work as often now that I do it this way, replacing and re setting the clock on everything at once. 3-5 years without worrying about it as opposed to dealing with it every 1.5-2 years. When I do brakes at either or both ends of the car if the rotors need any work at all they go in the trash.
    The last time I needed a brake overhaul the chain by me that I revert to using once I get well out of the warranty period on my cars charged me in the neighborhood of half what the dealer wanted. They only have to make a profit on brake work. They do not need to inflate the price of my brake work to cover slim used and new car sales profit margins.
    They get my business for brake work and oil changes. I do the dealer if I am throwing a transmission drain and fill in because I want to know the correct fluid is going in and they follow the Toyota procedure to the letter.
  27. Jun 15, 2021 at 1:09 PM
    FirstTruck
    Stock, for now
    Open a beer, jack up the truck, remove wheel (5 nuts), remove brake pads (2 springs and two pins), remove caliper (2 bolts), remove rotor (persuader)
    Now that u know the “How to”, yr next question would be “what do u guys recommend using?” Correct? Lol
