Rear Brake Noises 21 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cdnjoe, Nov 3, 2024.
  1. Nov 3, 2024 at 11:41 AM
    Cdnjoe
    Cdnjoe [OP] New Member
    Hello there, I just did my front and rear brakes about 56K KM in..
    Fronts I had to fight 1 side and cut out the pad pins..but after getting new pads in hugh difference and seems to be working great.
    Did the rears also,
    I used BC1304 Bosch pads, kept mostly the original hardware is is seemed ok..
    After changing them I am getting a grinding nose and squeaking..
    Pads are on the correct way, ceramic facing the rotors..I had a bit of a hard time getting in the new pads on the insides of the rotors..
    I have gone for a few drives with it, and braked hard, and also tried backing up and braking hard..
    I put truck back up on stands took rear tire off and when I spin the other wheel I can still here this grinding some times squeaking..rotor did not look like it was a siezed caliper as can turn by had faily easily also I dont see any big scratches appearing on the rotors in the glazed area lol.
    I did lube up the tips of pads they go in to the metal hardware and also the hardware..
    I had to reuse 1 of the old squealer hardware as they didnt include 2 in the pack..
    Appreciate some directions, I am just average user with some basic automotive..
    Thanks
  2. Nov 3, 2024 at 11:47 AM
    Cdnjoe
    I only change pads as original rotors both looked good minimal rust etc..
  3. Nov 3, 2024 at 11:47 AM
    Cdnjoe
    checking the backing plate, but I dont think its bent but going to double check
  4. Nov 3, 2024 at 11:48 AM
    Cdnjoe
    I have not touched the parking brake yet either
  5. Nov 3, 2024 at 12:07 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Did you happen to bend the dust plate in the back of the rotors while installing?
  6. Nov 3, 2024 at 8:14 PM
    Cdnjoe
    no dust plate was fine..I found the issue. When I put in the pads last night I hammered in the hardware a bit to hard lol it was slightly touching the rotors and thats what was causing the noise..so today I removed all the hardware, put in new..(the abatment clips) and lubed it and put pads back in..much better..thanks :)
  7. Nov 3, 2024 at 8:15 PM
    Cdnjoe
    back in 3-4 years when wife kills these..lol
  8. Nov 3, 2024 at 8:17 PM
    Cdnjoe
    https://www.youtube.com/watch?v=SiWkVe3vXys I had to chisel out my drivers side front pins, just like this vid..it was helpful..driver side front I was able to hammer the pad pins back and forth with some PBblaster..to get them moving and then punch them out..was a chore, hardest part I would say..;P
