Rear axle upgrades
Discussion in 'Sequoia 1st Gen (2001-2007)' started by NateB04, Apr 18, 2024.
  1. Apr 18, 2024 at 9:38 AM
    NateB04
    NateB04 [OP] New Member
    Nathan
    04 Sequoia 2wd
    Electric radio fan After market radio and speakers.
    Hi I have an 04 SR5 Sequoia two-wheel drive looking to upgrade the axle as well as suspension for Towing any thoughts or comments are welcome
  2. Nov 4, 2024 at 11:17 AM
    NateB04
    Nathan
    04 Sequoia 2wd
    Same as me I'm looking to upgrade as well if possible
  3. Nov 4, 2024 at 11:22 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Take a gander at the OP of this thread lol.
    You're in the less active sequoia section. What kind of upgrades are you looking for?
    OldGuy03 and des2mtn like this.
  4. Nov 4, 2024 at 11:38 AM
    NateB04
    Nathan
    04 Sequoia 2wd
    Same as was mentioned in the first post looking to upgrade the axle and rear suspension for Towing
  5. Nov 4, 2024 at 11:38 AM
    NateB04
    Nathan
    04 Sequoia 2wd
    Also could you point me in the direction of a more active place to post?
  6. Nov 4, 2024 at 12:06 PM
    You were responding to your own original post.
    OldGuy03 and NateB04[QUOTED][OP] like this.
  7. Nov 4, 2024 at 12:08 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    You're not going to be able to increase your towing capacity from how the vehicle came stock. Your axle is plenty strong for any towing you should be doing with this vehicle. If you change your rear coil springs to something like the Dobinson C59-345, you won't sag as much in the rear when you're towing. The rear will be lifted while unloaded though. Airbags can compliment your spring setup to eliminate the sag while improving your handling if plumbed correctly.
    OldGuy03 likes this.
  8. Nov 4, 2024 at 2:28 PM
    NateB04
    Nathan
    04 Sequoia 2wd
    Yeah that's the conclusion I had already come to but I wasn't sure if there was anything out there somebody done that may or may not have helped I appreciate that
