Rear auxiliary lights
Discussion in 'Lighting' started by counselor, Jun 26, 2018.
  1. Jun 26, 2018 at 9:26 PM
    counselor
    counselor [OP] New Member
    2017 Cement Tundra TRD Pro
    I have a 2017 TRD Pro. Considering adding aux rear lights, maybe increased back-up lights, but thinking additional lights for off road work. Probably LED. Suggestions?
    Jsena and 831Tun like this.
  2. Jun 26, 2018 at 9:30 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    @1UPPER did a cool setup that I’m thinking of doing too.. looks pretty easy
    1UPPER likes this.
  3. Jun 26, 2018 at 9:32 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    For off road I run some rear facing amber pods attached to the bed rail behind the cab. That's so the guy behind me can see me through the dust. Before going with and aftermarket rear bumper I cut my OEM bumper ends and put some flush mount pods on a switch for auxiliary back up lights, those are white.
  4. Jun 26, 2018 at 9:41 PM
    MOQS
    MOQS New Member
    Gary
    Missouri
    2017 SR5 4WD Crew Max
    3/1 leveling kit, DV8 front bumper, Smitty Built X20 winch, Spyder head lights, Eagle Eye tail lights, American Racing ATX 18" rims, General Grabber x3 33x12.5x18 tires. TRD Pro front grille. Rigid Industries 's R2-46 Driving Pair, BAK Revolver X2 Tonneau Cover, GoRhino RB10 Running Boards, Rugged Ridge 3.5" Fog Lights, Rear painted bumper(Black), Tinted windows, Weather Tech window deflectors
  5. Jun 26, 2018 at 11:11 PM
    counselor
    Great. Thanks for the responses. Anybody else?
  6. Jun 27, 2018 at 4:59 AM
    Cfincke
    San Antonio
    I installed some flush mount Rigid pods with the diffused lens. Have them wired to a switch that i can turn on anytime.
  7. Jun 27, 2018 at 5:19 AM
    War Machine
    War Machine SSEM # 5 3MW
    MOQS, csuviper and 1UPPER like this.
  8. Jun 27, 2018 at 5:49 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Do you prefer to have your rear lights down at the rear bumper height or more up high? I have the rear bumper lights and I also have a 50” Lightbar facing the rear below the rear window. Rigo fabrication has a couple various brackets to mount single led pods or large light bars from the OEM tie down bed rails.
    NewImprovedRon likes this.
  9. Jun 27, 2018 at 7:20 AM
    dumbassdave
    dumbassdave Member
    Dave
    2016 Crewmax Limited
  10. Jun 27, 2018 at 9:19 AM
    MOQS
    MOQS New Member
    Gary
    Missouri
  11. Jun 27, 2018 at 10:01 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I have a Fab Fours rear bumper, so my install won't help you but if you check my build thread post #16 there is a picture of the lights under my bumper. I have added lights in this manner to 5 different trucks/SUV's. Most of them, I have been able to use an existing bolt to mount. I am not very impressed with my current Amazon Cheap LED's. I'm thinking of going back with 55 watt non LED. I have always wired direct so I can use them without the ignition on.
  12. Jun 27, 2018 at 10:15 AM
    War Machine
    I’m heading out of town in the morning, so I may not get a chance before I get back. That said, I mounted them to the nerf bars. It was easy and secure, but I think them being so close to the ground are causing the bad hot spots underneath. I’m considering moving them to the rocker panel, but I’m not sure if that will make a ton of difference.
    MOQS[QUOTED] likes this.
  13. Jul 14, 2020 at 3:07 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Which harness did you buy and how did you route it?
  14. Jul 14, 2020 at 6:22 PM
    Cfincke
    San Antonio
    I have a relay fuse box for auxiliary equipment under the hood. The switch/trigger wires run into the cab and plug into the switches. No different than the relay harness that comes with the lights or the stand alone harness you buy on Amazon
  15. Aug 11, 2021 at 6:37 AM
    CoryShap09
    CoryShap09 New Member
    Cory
    2020 CM XP
    Are your painted bumper ends plastic or metal?
  16. Aug 11, 2021 at 7:00 AM
    My harness is zip tied to the main harness along the frame rail from the rear all the way to the engine compartment.
  17. Aug 11, 2021 at 10:34 AM
    Cfincke
    San Antonio
    They are factory plastic. Under the plastic is metal that has to be cut thru as well
    831Tun likes this.
