Reaplced liftgate but wiper and defogger don't work
Discussion in 'Sequoia 1st Gen (2001-2007)' started by foxcorner, Jul 4, 2024.
  1. Jul 4, 2024 at 4:02 PM
    foxcorner
    foxcorner [OP] New Member
    Northern Colorado
    2001 Sequoia still going strong
    Hi all,
    We've got a 2001 Sequoia SR5, which we've had for about 17 years, and we love it! It has treated us really well.
    Recently, we bought a nice-condition rear liftgate from a salvage yard, to replace the original, which was rusted and had suffered from pretty much every fault that Sequoia liftgates suffer from. :)
    However, the new liftgate was from a 2006 model, with the updated rear light clusters. That's not a problem - the lights work just fine without modifying wiring. However, the rear wiper and the rear defogger aren't working. I'm guessing there was a change to the wiring between the two model years.
    I have kept the wiper motor from the old liftgate in case I find that the new one's dead.
    I've started peering at some wiring diagrams, but I suspect that ultimately my approach will have to be to open things up and play with a multimeter.
    However.... Just in case any of you guys have tackled this problem before, I'd be grateful for any wisdom. :)
    Thanks!
  2. Jul 12, 2024 at 11:58 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I'm not sure this works for all years but there's a reset procedure that has helped me with these sorts of issues. Roll the window all the way down then back up, after it's up, hold the up button for 10 seconds.
  3. Jul 12, 2024 at 12:19 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    I had similar experience as to what rock climber posted. Basically if the truck isn't certain the window is all the way up it won't let the wiper or defroster run. I believe the remedy was as simple as rolling the window all the way down and then back up. That acts like a reset of sorts. I don't recall having to hold anything for 10 seconds (it was a while ago so maybe)
  4. Jul 12, 2024 at 8:04 PM
    foxcorner
    Northern Colorado
    Interesting! I'll give it a try - thanks!
  5. Sep 17, 2024 at 6:42 PM
    xSOLOx
    xSOLOx New Member
    03 sequioa
    Lift. Snorkel. 05 lights. 255/80/17s
    Did you figure anything out with this. I just swapped an 05 hatch and lights to my 03 and got everything working except the wiper.
  6. Sep 17, 2024 at 9:03 PM
    foxcorner
    Northern Colorado
    Sorry xSOLOx, I haven't tried it yet. I've been putting it off until winter's a little closer. :) I suspect I'll be testing wires with a multimeter to see what goes live on the car body, and then tracing wires from the wiper to the connector, and then maybe re-wiring.
  7. Sep 18, 2024 at 2:50 AM
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    You aren't going to try rolling the window down and back up until winter is closer? Or did that not work?
  8. Sep 18, 2024 at 8:12 AM
    foxcorner
    Northern Colorado
    Sadly, that didn't work. :(
