Readylift
Discussion in 'Suspension' started by Krackerjack, Oct 7, 2019.
  1. Oct 7, 2019 at 7:19 AM
    Krackerjack
    Krackerjack [OP] New Member
    2020 Tundra TRD Sport Metallic Grey
    Hi all,
    I’m thinking of getting the readylift 3/2 lift for my 2020 Tundra TRD Sport. Anyone have the lift on an older model and what do you think of it?
    Mountun Goat likes this.
  2. Oct 7, 2019 at 7:39 AM
    showtime240
    showtime240 New Member
    Its a standard spacer/block lift.
    Why not spend a little more and get 5100s and some shackles for a 3/2
    or spend a little more and get 6112s and shackles
    or spend a little more and get OME 612s and Dakar Leaf Pack
    or spend a little more and get some Kings
    or spend a little more and get long travel
  3. Oct 7, 2019 at 4:10 PM
    Krackerjack
    With this in mind I’m thinking the BDs 8” with coilovers and reservoirs
  4. Oct 7, 2019 at 4:11 PM
    Krackerjack
    I can’t decide is the 4/2 is worth the extra 700 for control arms and a little bit more clearance. I already have the bilstien shocks so I don’t need more travel.
  5. Oct 7, 2019 at 4:18 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I did the 3/2 lift and wish I would've just waited and did a 6" lift
  6. Oct 7, 2019 at 6:57 PM
    Krackerjack
    I use the truck for work a whole bunch and don’t want to do that high right now
    Boerseun and Mountun Goat like this.
  7. Oct 7, 2019 at 8:10 PM
    I have it on my 2013 with 285/70/18's (34's) on a 0 offset. It's fine for a daily driver/street use truck. Quite a few of us running that setup. Not recommended for offroading though. Ride is pretty much same as stock. As mentioned, just depends on your intended use and budget.
  8. Oct 7, 2019 at 8:32 PM
    Krackerjack
    I do light off roading, just some easy trails and boys being boys. Will it affect the performance for better or no effect?
  9. Oct 7, 2019 at 8:37 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    :rofl::rofl:Yessssssss
    showtime240[QUOTED] likes this.
  10. Oct 7, 2019 at 8:39 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    If anything less overtime. More wear on drivetrain wearables. :anonymous:
  11. Oct 7, 2019 at 8:40 PM
    Krackerjack
    Not exactly sure what that means.......
  12. Oct 7, 2019 at 9:10 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Just saying lifts can cause premature wear on items like ball joints and universal joints.
  13. Oct 8, 2019 at 5:40 AM
    Most will recommend not offroading at all as a spacer lift is a completely different setup compared to coilovers and shackles. Others will chime in but there have been instances of guys snapping lower shock mounts offroading with a spacer kit.
  14. Oct 9, 2019 at 5:12 PM
    Krackerjack
    Gotcha. Thanks for the clarification
    Mountun Goat[QUOTED] likes this.
  15. Oct 9, 2019 at 6:24 PM
    runCMD
    runCMD BAMF Nerd
    2016 Radiant Red CM SR5 TRD OR
    3/2.5 BOSS lift, 35s
    After issue after issue with alignments using my 3/2 with tuff country UCAs, I just ordered a BOSS shock setup and some SPC UCAs. Bought my truck with the spacer lift so not sure what stock is but hoping for an improvement on ride quality too. My tires cost way too much for problems.
  16. Oct 10, 2019 at 7:47 AM
    Toytec Boss kit or Boss 4x4 setup? The Toytec has 700 lb springs so it will stiffen the front but handle bumps better. I'm saving my $ to switch out my spacer kit as well.
  17. Oct 10, 2019 at 10:32 AM
    runCMD
    runCMD BAMF Nerd
    Toytec Boss, I'm leaving the block in the back after talking with David but replacing the shocks. Front spacer is getting replaced with Boss 2.0
    I think that's right, but might as well get everything nice while we're at it right :) . I'm kicking myself for not buying them when Amazon had them for like $450
    15Yota likes this.
  18. Oct 10, 2019 at 10:40 AM
    Yeah I missed that sale too. I would remove the block and go with shackles.
  19. Oct 10, 2019 at 10:42 AM
    runCMD
    runCMD BAMF Nerd
    dont want to hijack the thread, but i thought about going shackles, not going to quite get the same lift i have in the back i dont think and would need to figure out replacement U bolts etc - havent seen a lot of options for that. i can get stuff done on the truck but im still a dummy
  20. Oct 10, 2019 at 10:44 AM
    Toytec has a 1/2 block that you can use along with the shackles. They have u bolts as well.
  21. Oct 10, 2019 at 10:49 AM
    runCMD
    runCMD BAMF Nerd
    migh have done that along with my original order but now I guess I'll just have to wait till later.
