Readylift 8" with Fox 2.5 Coilovers
Discussion in 'Suspension' started by BRYMTIME, Aug 22, 2019.
  1. Aug 22, 2019 at 7:47 AM
    BRYMTIME
    BRYMTIME [OP] New Member
    Andrew
    Portland, TX.
    21' 1794 CM
    Zone Offroad 5 Inch Lift Nitto Ridge Grapplers 35x12.50xR20 Fuel Wheels - Rogue D709 Chrome Delete - Match Paint & Wrap LED Lighting Upgrade (Headlight Revolution) Decked Truck Bed System Full Factory Speaker Swap - Installed JL 10 Inch Subs & Amp. Helix Door & Dash Speakers. ( All Equipment & Custom Sub Box - Tech 12 Volts)
    I'm looking to replace my BDS 7" lift in the front with Readylift 8". I want to keep my Fox Coilovers, and run with the Readylift setup. Is this possible? Anyone running this? Thanks in advance
  2. Aug 22, 2019 at 8:00 AM
    Bigboitundra
    Bigboitundra New Member
    2018 tundra crewmax
    7 inch lift
    You don't like your bds lift?
  3. Aug 22, 2019 at 8:06 AM
    BRYMTIME
    Andrew
    Portland, TX.
    21' 1794 CM
    I do but I've had a hell of a time with tie rods rubbing, scraping etc. I had the caster adjusted to avoid tie rod hitting and now it's so far back it scrapes when I'm offroad or hit large potholes etc.
    From what I've read it sounds like the readylift 8" will correct all the issues I have and give me closer to factory angles.
  4. Aug 22, 2019 at 9:23 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    Readylifts are not meant for any aftermarket coilovers. The aftermarket coils will throw off alignment and could be a bitch. Now, this isn't always the case, but ive actually spoken to the guy that designed this lift (I have the same lift on my truck). He says the readylift is specifically designed for OEM suspension parts to retain factory geometry.
    I believe if you add coils, you have to also swap the tie rods from one side to the other, I don't remember all the details. But it can be done, just has to be aligned perfectly or you could run into some issues.
    Im sure there are some guys on this site that have the coils on RL 8" and they have no issues, but just to give you a heads up on what I have heard.
  5. Aug 22, 2019 at 11:04 AM
    Bigboitundra
    2018 tundra crewmax
    7 inch lift
    I'm running a 7inch pro comp lift.. and my truck rides great...
  6. Aug 22, 2019 at 11:08 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Mine does too!
  7. Jul 8, 2020 at 12:23 PM
    mjgonz1
    mjgonz1 New Member
    Michael
    Milwaukie Oregon
    2018 trd sport white crewmax
    Interested in trd dual exhaust
    Any resolution to your tie rods rubbing? Had bds lift installed two days ago with coil overs and I've got tie rod rubbing the coil over on both sides...
  8. Jul 8, 2020 at 12:39 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Aren’t the coachbuilder tie rods meant to fix this exact issue?
