Readylift 3/1 w/ Bilstein 5100s
Discussion in 'Suspension' started by vnguyen1292, Feb 9, 2021.
  1. Feb 9, 2021 at 10:41 AM
    vnguyen1292
    vnguyen1292 [OP] New Member
    Hi there,
    I am new to forum too. Just curious that the Readylift 3/1 and 4 5100 Bilstein shocks are compatible? I mean can they be as a combo?
    Thank you
    Saltyhero13 likes this.
  2. Feb 9, 2021 at 11:16 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    do not stack lifts. either go with the ready lift or the 5100's. the 5100's do not have a 0" setting so you should not use them with a spacer lift.
    also, the 5100's would be a better lift than spacers. get 5100's for the front lift and blocks/aal/shackle for the rear as well as a longer shock that accommodate the rear lift.
    frichco228 likes this.
