Ready Lift SST Question
Discussion in 'Suspension' started by H2OSkier, May 6, 2020.
  1. May 6, 2020 at 11:07 AM
    H2OSkier
    H2OSkier [OP] New Member
    2010 Tundra 2020 Tundra- purchasing
    My apologies if I am posting this in the wrong forum.
    I am looking at purchasing a 2019 Tundra Pro Sport. It has a Readylift 3"/2" level kit in it. Underneath is a set of Nitto Terra Grappler G2, 305/50R20.
    When I went to Readylift's website, it indicates that if you install this kit you must change out the TRD shocks on the truck....but it doesn't look like the truck I'm looking at changed the shocks out.
    Couple of questions...
    1. Should this be of concern?
    2. Under the tire/wheel forum, I can't find that tire size. It doesn't look like any trimming has been done on the truck. Issues I should be concerned about??
    Any and all help is greatly appreciated.
  2. May 6, 2020 at 11:16 AM
    MaxYota
    MaxYota GrilledCheese
    Murf
    MS Gulfcoast
    2019 TRD PRO VooDoo Blue
    Mighty Mouse suction cupped to the review 8 ball shifter. Driver side "Oh poop" handle. Smoked side window deflectors. ReadyLift TRD PRO +2 for front. 1.5" ProFormFab Shackles + 1" ToyTec block for rear. SDHQ Hidden winch mount with Badlands 9000 winch. 305/70r18 Cooper Discoverer STT PRO
    The tire is a 32x12 but as far as the shocks go I don’t know. Is your truck a trd Sport or a TRD Pro. Pro come with a waaay different shock than a Sport. My ReadyLift is designed for the pro and is considers a 4” lift.
  3. May 6, 2020 at 11:23 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    "Tundra Pro Sport" doesn't exist. You should get a confirmation of the trim level before proceeding.
  4. May 6, 2020 at 11:52 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    It is probably the TRD Sport package, 20 inch wheels, road valved shocks and a rear TRD sway bar.
  5. May 6, 2020 at 1:22 PM
    H2OSkier
    It has both sway bars on it. My concern is that it has the ReadyLift SST level kit in it and on the ReadyLift website it indicates that it doesn't work with the TRD Fox shocks....this once seems to have the TRD Fox shocks on it. Do I need to worry?
  6. May 6, 2020 at 2:48 PM
    frichco228
    Does your bed have TRD PRO stamped into the metal on the side? Actually stamped, no sticker? If so, you have a PRO and the 3/2 kit is not designed for it, since the PROs are actually about 2 inches higher from the factory. Take a few pics of the truck and post em.
  7. May 7, 2020 at 5:21 AM
    Just remove the spacer kit and replace it with something better.
