Re-Painting / Re-finishing Cast Alum Rims - What primer to use for NY winters
Discussion in 'General Tundra Discussion' started by Drifthopper, Oct 18, 2020.
  1. Oct 18, 2020 at 7:44 PM
    Drifthopper
    Drifthopper [OP] New Member
    '20 Limited Double Cab Silver Sky
    What type of primer should be used for repainting cast aluminum rims..?
    I bought an older set of aluminum Tundra rims that I want to use for winter snow tires.
    Wire wheel and sanded the flaking, bubbling original finish off as best i could.
    I'm not a paint guy, so a friend offered to re-paint the rims for me, but he is not sure what type of primer to start with to re-finish the raw cast aluminum.
    I'm in New York, so the rims will be subject to harsh road salt conditions.
    Any input is appreciated.
    YardBird likes this.
  2. Oct 19, 2020 at 7:36 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Not a paint guy either but didn't think Aluminum was good to paint. Powder coating may be a much better option.
  3. Oct 19, 2020 at 8:24 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Do research on cleaning aluminum for paint first, then get a good DTM (direct to metal) epoxy for step one. Then paint with whatever you want, I recommend base coat clear coat. But as stated earlier powder coating would be best for wheels.
    YardBird and Drifthopper[OP] like this.
