Re-paint failed clear coat areas
Discussion in '1st Gen Tundras (2000-2006)' started by rtkman, Aug 22, 2025.
  1. Aug 22, 2025 at 10:08 AM
    rtkman
    rtkman [OP] New Member
    South MO
    2017 TRD Pro CM 4wd, 2013 TSS CM 4wd, 2004 DC 4wd Ltd, 2002 AC 2wd SR5
    Are there any tips to successfully remove old clear coat layers and reapply clear to the existing base coat?
    My 04 DC is peeling on the hood and top, but a total repaint/clear is a bit expensive for my use.
    (Phantom Gray - 1E3 color code)
    Thanks
  2. Aug 22, 2025 at 10:35 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 55k mi
    YouTube is your best bet. Sand, prime, paint, and clear. Or get a small sheet of vinyl wrap and just wrap the hood and top.
  3. Aug 22, 2025 at 1:29 PM
    You're one of probably 2-3 dozen people with green or red trucks I've seen ask this question since I got here. You can ask 10 different people this question and you'll get half a dozen different answers, ranging from, "fuck it, why not?!" to "no, repaint".
    My short answer is: No. Not effectively, at least, in a way that's going to hold up for more than a couple-few years, if done perfectly.
    It's legitimately too difficult to sand away only the clear, to the basecoat, evenly. And while you can sand the edges smooth and feather in the clear, chances are it's going to be noticeable, and if not, if the edges were already lifting up, the rest of the paint you don't clear will be bubbling/failing before you know it. Understand, the clear is foggy and peeling because the bond between the clear and base coat has failed. The only real solution to that is to fully take off the clear, which is virtually impossible to do "cleanly" because 80-90% of the bond is still intact everywhere else.
    Your best bet is to strategically repaint certain areas. For example. If the roof and the hood are toast, have someone repaint between the roof racks, and repaint the hood, it'll make a marked difference in appearance. Repainting the fender flares can help a lot also. These are all things you can probably get done for a few hundred bucks, and it'll refresh the truck a lot. But in all my years of working on cars, I've yet to see anyone successfully take a vehicle that wasn't properly washed and waxed, and thus has clearcoat failure, actually fix their clearcoat in a way that didnt look like shit a few years later.
  4. Aug 22, 2025 at 2:14 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Having an ugly red Tundra with failed clearcoat after 25 years in the Southern sun, I’ve come to the same conclusion as @shifty`.
    F.I.LetGoFishing likes this.
  5. Aug 22, 2025 at 2:40 PM
    F.I.LetGoFishing
    F.I.LetGoFishing New Member
    Karl
    Jacksonville Florida
    2001 4x4 4.7
    It’s a tundra thing
    01 and hasn’t had a bath (except the redneck car wash) since 2006
    Roof and hood are rusted and clear coat peeling on flairs
    My 95 taco is the same color of green, has had a far more neglected life but not the lose except at the drivers window where one’s arm would sit and stone pings on the hood.
  6. Aug 22, 2025 at 2:43 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    This right here.
    Personally I just live with it on the 04 sequoia we have. I have considered just using a line-x type of restoration but I'd rather spend money on LBJ's and other known wearables.
    shifty`[QUOTED] likes this.
  7. Aug 22, 2025 at 4:19 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    My green 2006 has bad clearcoat on top of fenders and tops of doors. I don’t intend to do much with it I wax what clearcoat is left and deal with it. I live in SE Texas so the suns going to just continue to fry it
    OldGuy03 likes this.
