Re-alignment when installing new shocks?
Discussion in 'Suspension' started by Mackazon, May 29, 2022.
  1. May 29, 2022 at 8:36 AM
    Mackazon
    Mackazon [OP] New Member
    2014 SR5 2wd
    10ply, RAS
    New to forums so forgive if something isn’t phrased or done correctly. 2014 stock except for ten ply and RAS. Original OEM suspension 45k miles. 75% yearly milage is towing 7000+#, and payload near maxed or few hundred over (I know, I know…). I do not like the unloaded rake of one and half inches from RAS, but worth it when trailering. Was looking to install new shocks (maybe Bilstein 5100) on front only at this time just to make it more level 90% of the year. Local shop said has to be completely re-aligned ($$$). Is that true? Is that best way to go without creating more issues down the road? Im an old guy without big bucks to spend so wanting to minimize future problems by making best decision now. Thank you.
  2. May 29, 2022 at 8:55 AM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    An alignment should be like $80-$120.
    Mackazon[OP] and JLS in WA like this.
  3. May 29, 2022 at 8:59 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    It's a good idea. The new front coilovers will set your front suspension in a slightly different place than it currently is which will change the geometry slightly which is why it's suggested, even if you're not lifting it. If you plan to lift or level the truck it's even more imperative.
  4. May 29, 2022 at 9:11 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    At the current price of tires, an alignment would be even more of a no-brainer to me.
    Mackazon[OP] likes this.
  5. May 29, 2022 at 9:23 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    The general consensus is that an alignment should be done after the disassembly of the front suspension which is required to install new coil overs.
    Mackazon[OP] and Saltyhero13 like this.
