Rci skid plate....steel or aluminum?
Discussion in '2.5 Gen Tundras (2014-2021)' started by RollTide82, Mar 8, 2020.
  1. Mar 8, 2020 at 5:06 PM
    RollTide82
    RollTide82 [OP] New Member
    Michael
    2019 Tundra 4x4
    Just did my first oil change. Stupid stock skid is a bitch....never again. Looking to purchase one with a door for the filter. How much heavier is the steel one compared to the aluminum one? On the fence for which one I should buy....80 dollar difference isnt much....just wanted opinions. I will never go offroad so it really isn't for protection...thanks
  2. Mar 8, 2020 at 5:07 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Steel will be heavier and more sturdy if you're out wheelin or crawlin. Otherwise aluminum would be fine.
    Inquiringone and 15whtrd like this.
  3. Mar 8, 2020 at 5:10 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Get the steel one you will only have to take off access plate to change oil
    Black Wolf likes this.
  4. Mar 8, 2020 at 5:24 PM
    This ^^^
  5. Mar 8, 2020 at 5:44 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    If you dont need the skid for offroading maybe just cut an opening for the filter in your stock one?
  6. Mar 8, 2020 at 6:27 PM
    timsp8
    NY
    Doesn’t the aluminum have the access door too?
    Agent 607 likes this.
  7. Mar 8, 2020 at 6:31 PM
    TheBeast The Beach
    there is a bigger thread floating around with the same question :)
  8. Mar 8, 2020 at 6:31 PM
    TheBeast The Beach
    get Aluminium if no off road
    15whtrd likes this.
  9. Mar 8, 2020 at 6:47 PM
    A Bigly thread actually.................:thumbsup:
    Bob_Wiley and 15whtrd like this.
  10. Mar 8, 2020 at 6:54 PM
    Aluminum RCI..................[​IMG]
    WVI, Inquiringone, 15whtrd and 2 others like this.
  11. Mar 8, 2020 at 8:33 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    like others said get the aluminum if you're not gunna be off-roading. get the steel one if you are, the steel one will slide across rocks easier and won't gouge like the aluminum.
    Inquiringone likes this.
  12. Mar 11, 2020 at 6:38 PM
    Burdturger
    Burdturger New Member
    So can you change the oil with these aftermarket skids and not take have to remove the skid? I see the access panel for the filter but what about the drain plug? Does oil get on the skid? Does oil stain bare aluminum?
  13. Mar 11, 2020 at 6:45 PM
    15whtrd
    15whtrd Mr. Blonde
    You might get it on the edge of it but there’s clearance to access the drain plug. I installed a Fumoto drain valve.
  14. Mar 11, 2020 at 6:50 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Mall crawlers use Aluminum ones
    Off roaders use the steel ones
    RCI skids are some of the best. I’d recommend them. I sold my old ones to @joonbug.
    https://jowettperformance.com/products/coming-soon-billet-oil-cap-for-filter
    I just bought this from Jowett Performance.
    joonbug likes this.
  15. Mar 11, 2020 at 7:17 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    If not off-roading, does anyone just leave the skid plate off all together?
  16. Mar 11, 2020 at 7:53 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    I don't recommend this - the amount of damage a turkey does at 110 km/h on the highway made me very glad to have a skid plate. Took a lot of hammering to get it back to normal looking. I will always run a skid plate on a truck, not that I'd pay extra for a OEM off road package to get it, but if it doesn't come with one an RCI skid plate would be bought as soon as I signed the papers.
