RCI Arapaho bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by mfelton18, Feb 27, 2024.
  1. Feb 27, 2024 at 7:59 AM
    mfelton18
    mfelton18 [OP] I'M THE PROBLEM
    South Central Texas
    2014 Magnetic grey SR5 4x4 crewmax
    Eibach Stage 2, RCI armor, Method 705
    Is anyone currently running the RCI Arapaho bumper? Was looking at getting on on my rig but seeing if anyone has any input good or bad about it. I know RCI has a good reputation with there armor, just not sure about this bumper model. Any other suggestions? Trying to keep the weight down with some front end/ radiator protection.
  2. Feb 27, 2024 at 8:51 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    I'm waiting to see how the hoop works with the pro grill sensors. i offered to let them use mine but they already had someone lined up for the first week of January. haven't seen the results of the testing
  3. Feb 27, 2024 at 9:49 AM
    RCI is very new to making bumpers so there most likely isn't anyone here in the forum that has tried one yet.
  4. Feb 27, 2024 at 10:59 AM
    mfelton18
    South Central Texas
    Fair. I don’t have the sensors on my 2014
  5. Feb 27, 2024 at 11:00 AM
    mfelton18
    South Central Texas
    why no hoop? I currently have a full wrap around front bumper with head light and grill coverage and this thing is heavy! Trying to lighten up the load with some protection.
  6. Feb 27, 2024 at 11:10 AM
    2mchfun
    I'd suggest comparing the weight to stock weight. If there's a significant difference, check out the mounting location. Some heavy aftermarket bumpers only mount to the stock location directly at the end of the truck frame rails. Later after much stress, the plates begin to tear away from the frame rails. In the case of my heavy Ranchhand, it has bracketry that mounts to 3 locations, side of frame rail, front of frame rail, and the bottom of the frame rail. Aside from that, I like the version with the hoop. Good luck!
  7. Feb 27, 2024 at 12:29 PM
    mfelton18
    South Central Texas
    gotcha. In South Central Texas where I live there are an abundance of deer so made me want some type of front end protection.
    Sleeper16plat likes this.
  8. Feb 27, 2024 at 12:30 PM
    mfelton18
    South Central Texas
    I will do some research on the stock bumper weight. My current one has the plates that mount to the bumper and then the frame.
    2mchfun[QUOTED] likes this.
  9. Feb 27, 2024 at 1:05 PM
    2mchfun
    Another option would be additional custom brackets, might even be able to modify what you currently have.
  10. Feb 28, 2024 at 9:17 AM
    mfelton18
    South Central Texas
    I do like the Ironman bumper. Just think I want something with more protection in front for deer, hogs and other larger animals in South Texas. But Im sure the Iron Man will hold up fine to a deer strike.
  11. Feb 28, 2024 at 9:28 AM
    2mchfun
    If you haven't already looked into it, a brake upgrade can also be beneficial for wildlife damage protection. Alcon is the best kit out there and there's no reasonable comparison, but it's not cheap. Just something else to consider and benefit from.
    bulldog93 and (deleted member) like this.
  12. Feb 28, 2024 at 11:30 AM
    mfelton18
    South Central Texas
    never even thought about it. I will look into it! Thank you.
  13. Feb 28, 2024 at 12:27 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’m still holding out for the release of the smackaho series.
  14. Feb 28, 2024 at 12:39 PM
    2mchfun
    Bass Pro has you covered...
    Black Wolf and Silver17[QUOTED] like this.
  15. Feb 28, 2024 at 12:41 PM
    2mchfun
    Works every time!
    Silver17 likes this.
  16. Feb 28, 2024 at 2:24 PM
    mfelton18
    South Central Texas
    Classic
    Silver17[QUOTED] likes this.
  17. Feb 29, 2024 at 10:43 AM
    mfelton18
    South Central Texas
    Well I contacted RCI and the Smackaho front bumper series isn't coming out for some time total bummer. So I purchased the Arapaho bumper instead. Will do a write up once it arrives and is mounted.
  18. Feb 29, 2024 at 11:08 AM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    What was the weight of the stock bumper? I believe the Iron Man is 123# or something like that?
    Sierradevil likes this.
  19. Feb 29, 2024 at 11:28 AM
    b6graham
    b6graham New Member
    Not close to that
  20. Feb 29, 2024 at 1:05 PM
    2mchfun
    With the crush cans and all hardware?
  21. Mar 3, 2024 at 2:35 PM
    mfelton18
    South Central Texas
    Awesome! Thats heavier than most people think it is.
  22. Mar 3, 2024 at 5:48 PM
    mfelton18
    South Central Texas
    Indeed. How much is the stock bumper?? When I was moving it around it felt MUCH lighter than 123lbs.
    AZBoatHauler likes this.
  23. Mar 8, 2024 at 4:55 AM
    Marvthehamster
    Marvthehamster New Member
    CO
    2018 CM
    ADS/Deaver, Method's, 35's, RCI sliders
    I like the look of this bumper but it appears that a 30” light bar would be partially obscured since the opening isn’t continuous. This seems different to other manufacturers.
    Anyone seeing this as a potential problem?
  24. Mar 8, 2024 at 6:10 AM
    AZBoatHauler
    So.Arizona
    :confused:
    stock front bumper is well under 100 lbs.
    equin, 2mchfun and RobertD like this.
  25. Mar 8, 2024 at 11:00 AM
    mfelton18
    South Central Texas
    I noticed this also. Could be an easy fix with an angle grinder if it's a issue. For me I don't see it as one as the light bar will not be used much.
  26. Mar 14, 2024 at 1:35 PM
    b6graham
    b6graham New Member
    Ordered one and sliders too. Already have their skids sitting in my garage waiting to be installed
    TOYOTARIG likes this.
  27. Mar 14, 2024 at 3:02 PM
    mfelton18
    South Central Texas
    They just had a pretty good sale going on. Hope to get mine by next month and will do a full review once installed.
  28. Mar 30, 2024 at 11:14 AM
    Marvthehamster
    CO
    2018 CM
    You get this installed yet?
    I was in contact with RCI sales last week and they said lead times are 4-6 weeks right now. They have a couple promos running right now that would allow me to get the bumper, engine skid, trans skid, and cat guards for under $2k. Tempting…
  29. Mar 30, 2024 at 5:55 PM
    mfelton18
    South Central Texas
    just did today! Im typing up the full run down now. took them less than 3 weeks to get mine done and shipped to my door in Texas.
    b6graham likes this.
  30. Apr 14, 2025 at 1:05 PM
    Marvthehamster
    CO
    2018 CM
    I just ordered one of these bumpers with a 30" DD light bar. I also got the RCI skid package to replace my completely destroyed factory splash guard.
    Looking forward to getting some more chrome off this truck!
    BreyTundy and mfelton18[OP] like this.
