RC 6” lift CB vibration/shutter
Discussion in 'Suspension' started by BannzBeez, Nov 10, 2023.
  1. Nov 10, 2023 at 5:12 AM
    BannzBeez
    BannzBeez [OP] Trial and error educated
    Humble, Tx.
    2012 Tundra Dbl. cab 5.7 4wd
    N-fab chrome tube step Rockstar 20x9 wheels/ 34’s Nitto Ridge Graplers RC 6” lift/ M1 shocks MOOG upper/lower control arms/ ball joints/tie rod ends.. Replaced rear differential After market extension side mirrors with turn signal..
    Has anyone been able to successfully get rid of the vibration..?
    I have shimmed the CB down with the provided 1.25” spacers, had really aggressive vibration from dead stop acceleration up to 10mph, it would level off then again at 18-20mph as it shifted into 2nd, then an occasional shutter at highway speeds when pushing it to passing speed… added an additional 5/16” spacer and longer 70mm mounting bolts, the shutter got better, less aggressive nearly gone when when shifting to 2nd, and did not notice at highway speeds.. added another 1/4” with plate washers, it was about the same, however did noticeably better torque transfer to rear..if that makes since.??
  2. Nov 10, 2023 at 5:14 AM
    Any pics of the rear axle lift? Sometimes the angled rear blocks are installed incorrectly. Lots of complaints after RC 6” lifts for numerous reasons.
  3. Nov 10, 2023 at 6:05 AM
    BannzBeez
    Humble, Tx.
    Yes checked the shackle blocks first, they are correctly installed, short end to the front, has just over 5/16” difference front to back, rear differential is definitely rolled up to the front…
    Was considering adding more angle shim under the shackle blocks..?
