Rav4 suspension work
Discussion in 'Other Toyota Vehicles' started by FirstGenVol, Aug 7, 2019.
  1. Aug 7, 2019 at 9:14 AM
    FirstGenVol
    FirstGenVol [OP] Check the name tag. You're in my world now.
    East TN
    2002 AC TRD 4x4 V8
    I wasn't sure where to post this but I'm looking for some feedback on my wife's 2012 Rav4. I know we have a lot of members that have done suspension work on a variety of vehicles, not just Tundras. My suspension knowledge is limited to the Tundra.
    Our Rav4 just hit 110K and is likely due for some suspension work. I was planning to replace the front struts and rear shocks.
    The Rav4 appears to have a front strut/spring sold separately instead of a coilover. I really don't want to mess with a spring compressor. Should I reuse the springs and have a shop assemble them before I install?
    The rear appear to be a shock and spring separate from one another. I'm trying to figure out my options here.
    Is it safe to leave the rest alone for now? I can't see a need to replace the control arms and unless I find issues I'll likely leave the ball joints alone.
    https://parts.toyotaofcoolsprings.c...4-gas/front-suspension--struts-and-components
    https://parts.toyotaofcoolsprings.c...-2-5l-l4-gas/rear-suspension--rear-suspension
  2. Aug 7, 2019 at 9:29 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'd do the shocks/struts and let the other stuff go unless there's play in it. Maybe have some sway bar links on hand since they like to break.
    KYB is running a rebate right now for $50 off 2 struts and 2 shocks. They have a Strut-plus which is the whole strut/spring/mount assembly.
    This looks like a pretty decent video showing the removal.
    https://www.youtube.com/watch?v=sjZUJuGyuRU
  3. Aug 7, 2019 at 9:51 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Thanks. I'm not familiar with KYB. Pretty good brand?
    Since the rear spring is separate from the rear shock is it common to just replace the shock and leave the spring alone?
  4. Aug 7, 2019 at 12:29 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    They aren't Bilstein good, but IMO they're better than the Monroe options.
    I wouldn't mess with the rear spring unless they're broken or sag badly.
  5. Dec 19, 2019 at 1:53 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Anyone know what a shop would normally charge to swap original springs over to new struts? I'd rather not mess with a spring compressor.
  6. Dec 19, 2019 at 1:56 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    If you're bringing everything in loose maybe $30? Shouldn't take more than a half hour at most.
  7. Dec 19, 2019 at 2:05 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I did our 2011 a few years back with KYB's. Swapped the springs myself. Wasn't too hard but I've stared down and faced the spring compressor a bunch of times to feel comfortable doing so.
    The rear shock's mount bolt is stuck between a carrier on the back knuckle. You have to undo it to access the bolt. I have a video of it up on youtube if you search.
    FirstGenVol[OP] likes this.
  8. Dec 19, 2019 at 3:24 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Wife's rav4 v6 has the KYBs, not a fan honestly... Stick with OEM or the Sport Tokicos
  9. Dec 19, 2019 at 4:21 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
  10. Dec 19, 2019 at 6:05 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    DZ_[QUOTED] likes this.
  11. Dec 19, 2019 at 6:06 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm leaning that way. New OEM struts are only $100 per side. I was planning to reuse the springs.
  12. Dec 19, 2019 at 6:12 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    @ninjajay have you replaced the lower ball joints? Curious how easy it was.
  13. Dec 19, 2019 at 6:14 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'll check out your video. I found a thread on a Rav4 forum and everyone was cursing the engineers for those rear shocks. They say it sucks.
    Zebruaj[QUOTED] likes this.
  14. Dec 20, 2019 at 12:47 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I put KYB's on all 4 corners of our 2007 earlier this year. That thing ripped in the corners.
